Old 8/9/06, 12:51 AM
Peter Foxe Smothers's Avatar
Peter Foxe Smothers Peter Foxe Smothers is offline
Default How many Amps???
This is a first for me. Not one of the breakers was labeled as to how many amps it could handle....Check it out..
Foxe Smothers ( Owner / Inspector )
Pelican State Inspection
Your Best Choice for Home Inspection in the Shreveport & Bossier City Area!
www.PelicanState.Net
www.ShreveportHomeInspector.net
www.BossierCityHomeInspector.net
foxe@pelicanstate.net
LSBHI #10399
Old 8/9/06, 12:58 AM
Jeffrey R. Pope's Avatar
Default Re: How many Amps???
Is that the service equipment? The amperage is the least of your concerns here, however, it would be limited by the conductors feeding the bus bars.
Missing handle ties. . . direct taps. . .
That Square D has seen better days. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 8/9/06, 1:10 AM
It is on the otherside of the wall from the main disconnect. 100amp switch blade. How would you verify that the breaker to wire size was correct in this case? Lets say there were no other problems with the panel. No direct taps, double taps, missing breaker ties, breaker ties made of wire, neutrals and grounds bonded in the subs etc.
LSBHI #10399
Old 8/9/06, 1:37 AM
I assume you mean 100 amp "fused" switch blade? Or is an unfused switch?
If no fuses (or other type of OCPD), the conductor size after the switch would be the limiting (and most likely, determining) factor.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 8/9/06, 3:25 AM
Ted Allen Ted Allen is offline
Oh Mr. Pope there you go again...
Old 8/9/06, 7:31 AM
smcarthur smcarthur is offline
Please Note: smcarthur is a non-member guest and is in no way affiliated with InterNACHI or its members.
Call it out for at least 2 reasons. 1. There is no way to tell if that is a 20a or a 30a breaker on a #12 conductor. 2. Taps onto the main lug with undersize wire.
Old 8/9/06, 12:13 PM
If they don't have the amp rating molded into the handle they are not Square D breakers. They could be some kind of offshore knockoffs. I would like to pull one out and get a better look at it. Square D does make a switch that fits in a QO hole with no O/C protection so this could really be scary.
Old 8/9/06, 3:01 PM
Unmoderated Guest
Those are Square D QO breakers. Just old ones.
They had the amp rating on the side of the handle. Look closely to see if they faded away over the years.
HVAC Proper AMPS lking Inspecting HVAC Systems 2 11/25/07 9:53 PM
Sub Panel Amps mtimpani Electrical Inspections 5 10/1/06 10:47 AM
Another Service Entrance Amps Question pdickerson Electrical Inspections 2 8/7/06 4:39 PM
Service Entrance Amps? dtaylor Electrical Inspections 12 8/5/06 4:38 PM
What Can be the cause of this gporter Electrical Inspections 15 1/23/06 5:56 PM
