I was at a new home today and saw this crappy installation of the branch wiring (17 to 20 splices all crammed at the top of the panel). Is this something that you would write up? What would be the wording you would use if so? I tried to attach the picture but it was to big of a J-peg. If you know how to condense a j-peg file let me know and I will add it.
Thanks, Spencer |
Download software for pic reduction after that , by downloading any one of a number of free graphic programs.
PM me if you want help. |
Here's the picture. Talk about an abortion. . .
It is not filling a significant part of the wiring space so it is "legal". That sure looks like a screw up to me. They either left the wires short or had a copper theft and that was as high as the crack heads could reach.
"..... splices, and taps shall not fill the wiring space at any cross section to more than 75 percent of the cross-sectional area of that space."
What is happening to the industry, and why are people accepting this lousy crap and poor method of bootleg jobs done by hacks and hop heads! |
Notice the main breaker at the "top" of the panel? Me either, did they install the panel upside down as well?
Scott A. Figert www.sfigert.com www.nachi.org NACHI #06042595 Figert Building Inspection, Ltd. (419) 399-4472 Office & Home Sweet Home |
Not all MAIN are at the top of the panel here's a Square D from the other day
ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good Last edited by badair; 6/2/09 at 1:56 AM.. |
If the feed enters below the panel it would make sense to install it main down. Less wire to purchase and less gutter space is used. |
Here is a Cutler Hammer from a couple of weeks ago.
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father |
We would be concerned that the fill was greater than 40% and would have to show that Table 4 in the NEC Chapter 9 was complied with along with Table 5. This mess should be referred to a qualified electrician
What is the fill allowance for a splice?
Greg: The 40% fill in the pipe was where we were with this question, not the splice.
Mike Whitt is a non-member guest and is in no way affiliated with InterNACHI or its members.
Is that even an electrical conduit?
If it is a water pipe then all this other is for nill cause the pipe must be replaced which would mean that the complete installation would be addressed. Also there should be a bushing on the end of the pipe which again would address the splices. |
| Panel Inspection Safety | roconnor | Electrical Inspections | 10 | 9/24/06 10:02 PM |
