Old 8/3/08, 5:07 PM
Erol Kartal Erol Kartal is offline
Please Note: Erol Kartal is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Marginal Drip Loop.
Would you call out the top feed as not being a required loop? It's a close call and has not been an issue in 20 years.
Old 8/3/08, 5:08 PM
mnahrgang's Avatar
Default Re: Marginal Drip Loop.
I'd definitely document it, but I don't think I'd make a big deal out of it.
Mark Nahrgang
www.HeyMark.info
Old 8/3/08, 5:12 PM
My concern is that if I need to document it then it's a current issue.
Old 8/3/08, 5:13 PM
relliott's Avatar
relliott relliott is offline
Please Note: relliott is a non-member guest and is in no way affiliated with InterNACHI or its members.
Yeah, the part about it not causing issues could be part of you verbage.
At least it has 3 feet clearance and is under the soffit.
Just do not put it in summery of defects. (depends on your report style).
Old 8/3/08, 5:18 PM
Good points guys, thanks. It's been a while since I've had a borderline issue. I'm used to Scud Cruds TM where everything is messed up.
Old 8/3/08, 5:20 PM
Jeffrey R. Pope's Avatar
It sure looks close to that window. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 8/3/08, 5:24 PM
relliott's Avatar
Even if not quite 3 feet it is at the top section.
In the Chicago area , nobody opens the top.
Old 8/3/08, 5:37 PM
iniquette's Avatar
iniquette iniquette is offline
Send a message via ICQ to iniquette
LMAO Bob. I wouldn't make a big deal out of this either, but I don't think your attorney will like your reasoning.
Ian Niquette
Square One Home Inspection
Markesan WI 53946
www.squareonehomeinspection.com
Active Rain Network
INACHI Awards Portal
Want To Exchange Links?
What we've got here is......failure......to communicate.....
Old 8/3/08, 6:59 PM
You're assuming it's a window that opens vertically?
230.9 (A) Clearance from Windows. Service conductors installed as open conductors or multiconductor cable without an overall outer jacket shall have a clearance of not less than 900 mm (3 ft) from windows that are designed to be opened, doors, porches, balconies, ladders, stairs, fire escapes, or similar locations.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 8/3/08, 7:37 PM
Billy Boerner's Avatar
Billy Boerner Billy Boerner is offline
Send a message via Yahoo to bboerner
I would call the drip loop and the window. It's two close from what I can tell in the picture regardless. Robert look at it this way even if it didn't open at the top if a fire was blazen and it was your only way out and you had to kick the entire window out because someone in the family was a bigger feller like me and couldn't fit through the bottom... Now the window just turned into a fire escape!
Bill
Bill Boerner
STL Home Inspection Services
Serving St. Louis/Surrounding
(314) 805-2137
billy.boerner@gmail.com
http://www.stlhomeinspector.com
Drip Loop chunt1 Electrical Inspections 5 1/31/07 7:52 AM
Drip loop? jspringstead Electrical Inspections 1 7/5/06 10:25 PM
Lack of aluminum drip edge Brenda Exterior Inspections 26 6/16/06 8:28 AM
Loop Vent Charles Bottger Plumbing Inspections 22 2/19/06 1:32 AM
