If the mast bushing is disconnected or hanging from the mast, should the municipal electric utility company be contacted or a qualified electrician to make repairs?
| Find an InterNACHI certified Ohio Home Inspector (and anywhere else in North America) |
in the 1st instance I would call the power company as the bushing is on "thier" side of the meter, they may well tell you to hire an electrcian though. Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
When you say Mast Bushing are you speaking of the Mast Support Isolator that the grounded conductor connects to in order to support the service drop? . Generally the electrician would install this and if it is indeed that and it is hanging then I would indeed contact the POCO and then line up an electrical contractor as they will need to install the bolt or insulator and then the POCO will need to come and re-connect to it....they both will work together.
BTW...Gerry.....I did not forget ya fella....just trying to get back into swing after being away....I will be callin ya my brother.... Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
| Service Mast | jharrison | Electrical Inspections | 2 | 5/15/09 3:00 PM |
| Is a mast head really necessary? | jfunderburk | Electrical Inspections | 5 | 2/10/09 10:04 PM |
| securing the mast? | bthompson1 | Electrical Inspections | 6 | 4/26/07 9:01 PM |
| 125A from pole to 200A Panel | Jan Lombard | Electrical Inspections | 12 | 4/16/07 6:33 PM |
| Service mast | nbhi | Electrical Inspections | 10 | 9/23/06 11:58 PM |
