Notice on the left wall of the panel. I believe it is a type of hard particleboard. Is there such a term & is this a fire hazard?
Richard W. Washington, owner RW Home Inspections, Inc. www.RWHOMEINSPECTIONS.com Texas Real Estate Commission (TREC) Professional Inspector License #7238 Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter InterNACHI member since 2004 Based in Katy, serving Houston and all surrounding communities |
| Need a home inspection in Iowa? Check out InterNACHI's listing of Iowa certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
since the pic wasn't rotated it's on the top wall.
Not sure what the material is but it looks like I see two wires under one screw on the Neutrals .
Also for Canadians there is white and grounds on same buss not allowed in Canada Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Any idea why that stuff is in there?
I would call that out Richard. Modifying a listed electrical enclousure is not allowed. It is a safety hazard as well as a fire hazard.
I am sure the sparkies here can elaborate on this one from the NEC code. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Neutrals and grounds can't be on the same bar even in the service equipment? Didn't know that. I must be reading too many American posts.
It is no allowed in America either, but electrictrians do it all the time in the great U.S.A.
There is not enough terminals on the neutral bar anyway. That is why it is probably like that.
Possibly something to keep the wires from rubbing up against a sharp screw head. That being the normal mounting hole location on most panels.
Texan-bit-o-trash-wedge to hold conductors away from the front cover screw, trash should be removed...
Fig. 4. ![]() Neutral terminations See 110.14(A) for additional terminal requirements. Each neutral conductor within a panelboard must terminate to an individual terminal [408.41] — that is, don't put two neutrals on the same termination point. http://ecmweb.com/nec/code-basics/sw...nels-20100701/ ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
| Main panel installed at floor level in garage | jfrederick | Electrical Inspections | 5 | 7/5/09 8:39 AM |
| Electric Panel | dmozzillo | Electrical Inspections | 26 | 1/26/09 1:18 PM |
| Inside panel: neutral & ground bus same thing? | Drayman Eightysix | Electrical Inspections | 2 | 10/21/08 5:10 AM |
