In 2006 what was the maximum number of outlets allowed for 20A??
Not sure if they were going by 2005 rules or 2002 Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
| Need a home inspection in Vermont? Check out InterNACHI's listing of Vermont certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Is this a residential unit and are you referring to receptacles?
Code - yes Smart -no You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Yes residential, and let me rephrase. How many outlets (receptacles) are allowed on one branch circuit..
I know now it is 13, was it different for 2002 or 2005? Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
In residential units, receptacles are required by number and spacing. Limits for residential units are arrived at through load calculations...not rule of thumb. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 Last edited by jbushart; 1/20/11 at 12:52 PM.. |
Had a house with 16 today. All three upstairs bedrooms and the hall on one afci.. I thought it was wrong but did not know about earlier versions. I guess it would require a load calculation to verify. You usually dont see that many.
Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net Last edited by sfogarty; 1/20/11 at 1:03 PM.. |
His maximum only applies to commercial. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
David Hays All Points Home Inspections LLC Denver, CO 720-670-0366 allpointshomeinspect@yahoo.com www.allpointshomeinspections.org |
Just talked to a buddy of mine here and our ahj does have residential requirements. The 2011 and newer will now only allow 8 instead of 12
Better check with the code book unless you plan to use the "buddy of mine" reference when challenged. The AHJ is not allowed to deviate from the code but perhaps your municipality or county has amended it. In either case, you should have the actual reference at your fingertips, IMO.
He has been an electrical contractor for 30 years. I think I will go with what he says.
To my knowledge, in residential applications there is no actual limit on the number of receptacles connected in a brach circuit.
There is a minimum requirement, based on location in room, linear footage between receptacles, and usage (E.G.: dining room, kitchen, etc). Again, this is a MINIMUM requirement. Nothing about MAXIMUM. The number of receptacles has no bearing on the branch circuit, as they are connected in parallel. Each device plugged in has a resistive value, when that when placed in parallel, lowers the overall resistance of the branch circuit, thusly increasing the amount of current flow through the entire circuit path. Breakers trip thermally and magnetically. When the amount of current flow exceeds the breaker rating, it trips. It doesnt matter if it's 2 devices, 10 devices, or a hundred. |
| Kitchen outlets | lwootten | Electrical Inspections | 4 | 11/11/10 6:21 PM |
| ungrounded outlets! | gmaher | Electrical Inspections | 29 | 6/10/07 10:58 PM |
| Properly Testing GFCI Outlets | tchristopher | Electrical Inspections | 17 | 3/17/07 11:19 AM |
| Replacing 2-prong outlets with GFCI outlets | kshepard | Electrical Inspections | 7 | 6/24/06 6:58 AM |
