Texas Standards refer to "meter can". Is this a proper term?
| Need a home inspection in Utah? Check out InterNACHI's listing of Utah certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
The 2006 IRC refers predominately to "meter base". There are a couple of references to "meter cabinet, enclosure and socket" but never a "meter can" that I see. I'm not sure about the NEC, maybe a sparkie can comment.
Appears to have a few names.
Meter Can meter enclosures meter box meter base meter socket LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Mike is right, the two most prominent definitions I found was;
"Meter Enclosure" - a wood or metal cabinet, or metal socket, installed indoors or outdoors, in which the Company's metering equipment is located. "Meter Sockets" - a meter socket is the base portion of a socket type meter. There are numerous kinds of meter sockets such as light duty, heavy duty, multi-terminal, etc. all with various numbers and sizes of conduit openings. Each particular socket has a preferred application although some are interchangeable. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Thanks guys. Meter can soounded slang. If anyone has a searchable NEC see if meter can is in it. If not I will propose SoP be changed to "meter enclosure".
I used to tell people their roof was shot until a client asked me with what size bullet. PS Is there spell check on this board? Where is it? |
There used to be a spell check John, now I downloaded the Google Bar and it has one on there.
I think you are right on meter can (slang). LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
I suppose we'll have to change the language when we mention 'the terminations at the peckerhead'
Jeff Jeff Wicklander Corwick Home Services Join my business on Facebook
| CPSC -----> Recall on electric meter panels | pbolliger | Electrical Inspections | 0 | 10/15/09 11:23 PM |
| City electrical inspector says move the meter and panel | cbottger | Electrical Inspections | 9 | 4/4/07 8:59 PM |
