Yesterdays insection had the meter pan within inches of the rear exterior door. I was immediately going to call it out as within three feet, however, I can not find any reference for door clearance, only windows. Even code check mentions decks & balconies, windows, but not doors. Am I missing something?
Thanks, Fred |
brepanshek is a non-member guest and is in no way affiliated with InterNACHI or its members.
says nothing in the IRC book, I don't have the NEC book. Will get back
I don't think the rule is there to find. There are rules about the service drop but not the meter
1)If your electric meter will be
under a deck, the deck must be at least 7 feet high. 2)There must be 36 inches of unobstructed space in front of the meter. 3)There must be a 36-inch wide unobstructed travel path in front of the meter. 4)There must be at least 2 inches of space on both sides of the meter. 5)No structure may be built around the meter, except for approved meter rooms. 6)Doors or windows cannot be within one foot of the meter. 7)Meters located inside fenced areas must have gate access. |
Ian Gills is a non-member guest and is in no way affiliated with InterNACHI or its members.
Why is it a problem? The door could open on it I suppose or someone could hit it when entering, but why windows? To protect the burglar who's looking for something to get a leg up?
Brian, do you have a citation for all that? Where did it come from?
I was doing a search on building a deck and the requirments for a meter location awhile back and found these statments on the internet. I just copied them to a file for future reference, so I don't remeber exactly where I got this info. I don't have the NEC code book, so I may be wrong???
There is no violation pictured.
Agreed.....I don't see a problem with this installation. Atleast from what is seen in the picture.....
P.S. Marc...clean out your PM box...lol... Paul W. Abernathy |
lol......Again...Welcome to the MADNESS...I mean...NACHI
Paul W. Abernathy |
Hey Paul, I just use this as a guide line when doing side work. What restrictions are there when it comes to meter locations, and where may I find this. Thanks
Brian, the code only talks about working space. Your POCO (power company) are the one's who make the more restrictive rules on that. I think your POCO is Metropolitan Edison, so their rules are here: https://www.firstenergycorp.com/Buil....1rev_2006.pdf
Exhibits #3, 4, and 5 in their rules book are 90% of what you'll run into as a home inspector. If your POCO isn't MetEd, repost with who it is, and I can get a link to their rules book for you, if you're interested. Last edited by Marc D. Shunk; 2/17/07 at 6:04 PM.. |
Doors or windows cannot be within one foot of the meter. Check out...Guidelines for building decks, fences & additions: at http://www.novec.com/documents/WCApril2004.pdf Last edited by dvalley; 2/17/07 at 7:26 PM.. |
| City electrical inspector says move the meter and panel | cbottger | Electrical Inspections | 9 | 4/4/07 8:59 PM |
| Range Clearance | dsmith6 | Interior Inspections | 18 | 1/7/07 9:55 PM |
| Panel and Meter | jwilliams7 | Electrical Inspections | 10 | 6/21/06 5:49 PM |
