Here's a photo that another inspector sent me for my opinion. Apparently that is exposed SE cable between the meter and the panel. Does it need to be protected, i.e. in conduit?
| Find an InterNACHI certified Missouri Home Inspector (and anywhere else in North America) |
I would assume it's less than 7ft above the ground. I would say yes. Also, as configured, what keeps water out?
Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
Yeah, the bushing on the left looks especially suspect doesn't it? On the other hand, the POCO apparently was OK with it and it's stood the test of time it seems. No that that matters
I am not going to comment on the connector at the meter as it does not look like any I am familiar with. I will comment on the SE Cable. It does not need any protection as SE Cable is rated to be run exposed and when kicking in the protection it has to be in a position subject to the damage and nested between the meter and panel I would not call it out as subject to physical damage......
Paul W. Abernathy |
Thanks Paul. I'll convey that message to the inspector that asked me about it.
Looks like that may be one of the utilities ground straps around the WP connector on the left side.
| Panel Question | bsmith | Electrical Inspections | 11 | 5/27/09 9:59 PM |
| Commercial Sub Panel Question | mnahrgang | Electrical Inspections | 10 | 12/4/08 5:53 PM |
| Panel Question | thejnicki | Electrical Inspections | 18 | 10/7/06 1:07 PM |
