Old 4/25/11, 12:09 PM
John Gromkoski's Avatar
John Gromkoski John Gromkoski is online now
Default Microwave plug
Do you have a problem with this?
774 Manor Road
Staten Island, NY 10314
718-514-3393
Need a home inspection in Oklahoma? Check out InterNACHI's listing of Oklahoma certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/25/11, 12:20 PM
Robert Meier's Avatar
Default Re: Microwave plug
It's likely that the yellow cord cap is not listed for connection to AC cable, MC cable or a metallic flexible raceway.
Old 4/25/11, 1:27 PM
Bob Elliott's Avatar
Should have a junction box there with a wall plate preferably.
Old 4/25/11, 1:45 PM
Doug Edwards's Avatar
Putting a plug (female) on the end of permanent wiring basically turns it into an extension cord which is not to be used for permanent wiring in the home. As stated, should have terminated in a J box with an approved receptacle. So, Yes, I have a problem with it.
- John Stuart Mill
Old 4/25/11, 1:55 PM
I kind of agree with you but it is most likely attached at a junction box rather than plugged in at the unseen end of it.
Old 4/25/11, 2:45 PM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is online now
Since that type of socket end even comes loose when attached to a extension cord.BX or armored cable is double trouble.
1st The attachment cannot be secured properly
2nd It will never be used by electrician in this application.
3rd If it does not have a good tight connection it will not trip the breaker first and is a fire hazard.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 4/25/11, 3:44 PM
I agree with this comment the most.
I think it's a stretch to call it an extension cord as Doug mentioned, unless of course the end we cannot see has a similar arrangement.
774 Manor Road
718-514-3393
Old 4/25/11, 4:03 PM
KEVIN WOOD's Avatar
It is not an extension cord. It is either a BX armored cable or a BX protected sheaving.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 4/25/11, 4:27 PM
Judging from the photo I am guessing that it is any one of the three wiring methods (AC cable, MC cable or FMC) that I mentioned. Unless that's a special cord cap it's not listed to be terminated as shown in the photo. Normally we would just use a surface Wiremold box and receptacle for this application.
Old 4/25/11, 4:47 PM
KEVIN WOOD's Avatar
OPPS! I meant sheathing.
A note about it being BX it will not have a ground wire so if it does it might be new AC or MC armored cable.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 4/25/11, 5:26 PM
Some BX runs a ground wire through it.
Old 4/25/11, 5:46 PM
KEVIN WOOD's Avatar
[Correct] only the original 1960s BX has no ground.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 4/25/11, 5:50 PM
Are you referring to the thin aluminum bonding strip within AC cable?
Old 4/25/11, 9:41 PM
90 percent of the houses around here are wired in BX. Especially the older ones. Romex has only been widely used within the last 10 years or so.
774 Manor Road
718-514-3393
Help. What is the correct way to report a breaker that is too big. gromicko Electrical Inspections 77 5/10/12 6:13 PM
Microwave oven testing? badair Miscellaneous Discussion for Inspectors 26 3/11/09 7:53 PM
Microwave receptacle jwardenski Electrical Inspections 17 9/9/07 7:18 PM
Romex connected to male plug... OK? ghawley Electrical Inspections 20 3/4/07 6:05 PM
