Mike,
I received the two electrical bond testers that I ordered from you yesterday. Not only do they help me to comply with the new SOP, they work great, are high quality and will add some extra flash to wow clients during an inspection. Nice work! A big Bravo Zulu to you. www.capcityinspections.com/Bond_Tester_Order John Onofrey Licensed Professional Inspector Houston Home Inspection Houston Home Inspector www.texasinspectors.net John Onofrey President, Grail Media, LLC "Effortless Email Marketing" www.homehintsenews.com 2007 INACHI Inventions and Innovations Award Winner Free! Inspector Email Marketing trial click here |
Thanks John, I appreciate the kudo's & BZ. It's unfortunate that we are saddled with that new inspection requirement here in Tx but hopefully this will make it a little easier & quicker.
Excellence in Inspections Mike Boyett, TREC #7290 mikeb@capcityinspections.com Capital City Inspections Austin, Texas (512) 577-2579 Company blog is: www.capcityinspections.com/blog |
Cal I ask what the new requirement is, and what exactly that tester tests for?
I'd love to see the UL listing on those things. There is absolutely both a failure mode of the tool, a failure mode of the building's wiring, and a failure mode of an appliance (3 ways in total, at least) in which the operator of the test instruments can be injured or killed.
Got mine too. Works great. Have already run into the situation where I needed it to be a longer cord. Not sure what the answer is, as having too long of a cord would get in the way most of the time. And I am wondering how long till I lose the little plastic probe cover.
Thanks again Michael! When are you coming out with the CapCity all in one single pryer/raiser/resealer? Professional Inspector Level I Infrared www.AbsoluteInspections.net www.homeinspectorsplanotx.com www.homeinspectorsmckinney.com Absolute Inspections, LLC 972-463-0887 |
Got mine and it works great. Thanks Mike.
Funny you should ask that Kevin...I've thought about doing exactly that. Putting a little "TREC 2009 SOP Inspection Tools Package" together.
I've thought about simply offering an inexpensive 3-wire extension cord as an optional accessory and may very well do that. I found a 15' one at Lowe's that would work just fine if the 8' of probe wire wasn't long enough. Any more than that and it would get too unwieldy I think. Excellence in Inspections Mike Boyett, TREC #7290 mikeb@capcityinspections.com Capital City Inspections Austin, Texas (512) 577-2579 Company blog is: www.capcityinspections.com/blog |
What is the requirement in your SOP that you need this tester?
What specifically does it do? I have never seen anything like it. |
Just out of curiosity Kevin, can you describe that situation? Again, my thoughts have been that 8' of probe should get you from an outlet to any appliance.
Furnace/blower unit in attic and related gas pipes. Extension cord is an obvious answer, =), just trying to limit the amount of crap I have to carry around.
OK. At least on newer homes there should be an electrical convenience outlet nearby and within 8' of the furnace, huh?
There must be a receptacle, but there is no distance requirement.
Fluke isn't applicable/acceptable here? Or is this just an alternative? I've used ext. cord to good known outlet and gone from there.
Thanks, curious, Tim |
Yes, Tim...this is just an easier, cheaper, quicker alternative to a higher priced commercial meter. It has the ground connection 'built in' and the audible feedback really speeds things up.
| What's this video worth? | jtedesco1 | Inspection Education & Training | 5 | 4/18/08 9:24 AM |
| Handbook for Electrical Safety | pabernathy | Electrical Inspections | 1 | 1/1/07 1:14 PM |
| Electrical Safety Information | jtedesco1 | Electrical Inspections | 0 | 2/19/06 1:48 AM |
