I think something is missing.
So do I----------Quality control----
Dale Duffy Inspect Arizona Companies, Inc. Phoenix Home Inspectors, Inc. Scottsdale Home Inspectors, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
The panel cover, of course.
Jeff Jeff Wicklander Corwick Home Services Join my business on Facebook
Grounding Electrod Conductor?
tom |
Kenneth...I suspect you are referring to the uninsulated Neutral wire. Don't be too quick to condemn that, type SEU cable is permitted in certain circumstances and apparently has been common practice in years past. A sparky needs to explain this in more detail.
Excellence in Inspections Mike Boyett, TREC #7290 mikeb@capcityinspections.com Capital City Inspections Austin, Texas (512) 577-2579 Company blog is: www.capcityinspections.com/blog |
Without a wider shot, I'm not willing to say that anything is missing. Other than being a tad on the sloppy side, it looks okay to me so far.
This is getting dangerous, but I am agreeing with Marc again.
What are you driving at?? |
Christopher Griffin is a non-member guest and is in no way affiliated with InterNACHI or its members.
It looks like a DIY installation. The SE cable should be protected in a raceway, and have a protective bushing entering the service panel. The romex should enter via the 1/2 inch knockouts and be secured by cable connectors. And I see an unused green grounding screw that is likely there for a (missing) SE raceway bonding jumper, but don't see enough in the photo for further assessment of the grounding.
SE cable does not require a bonding jumper. There is nothing to bond. And a metallic raceway bonding jumper would simply go to one of the terminals on the neutral/ground bar in a main panel. Yeah, it's a mess, but I don't really see anything non-compliant about it. |
| Trussess - Is something missing? | Skip Erwin | Structural Inspections | 12 | 2/9/09 10:23 PM |
| Jim Bushart (look what your missing) | relliott | General Inspection Discussion | 71 | 1/8/09 8:34 PM |
| Whats missing Here?? | psmothers | Inspecting HVAC Systems | 7 | 3/18/08 4:25 PM |
| What's missing here? | jtedesco1 | Electrical Inspections | 10 | 12/19/07 9:11 PM |
