Old 6/7/07, 9:36 PM
cbrands's Avatar
cbrands cbrands is offline
Please Note: cbrands is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default moisture signs in panel
look at these signs of moisture in and under this panel.
Meter is directly behind this panel on the exterior wall.
We've had a little rain lately.
no moisture in the panel at time of inspection.
moisture meter showed the stains below the panel to be completely dry.
i'm obviously calling it out, but how many would defer and say an electrician's evaluation is necessary.
ID:	12127   moisture-signs-panel-100_2130-small-.jpg.jpg
Old 6/7/07, 9:40 PM
Marc D. Shunk's Avatar
Banned
Default Re: moisture signs in panel
Either condensation from warm/code air exchange through the meter to panel nipple or the meter hub or weatherhead is leaking. Not irreparable, but well worth documenting.
Old 6/7/07, 9:47 PM
cbrands's Avatar
underground service, so weatherhead is out.
but in either situation, it appears an electrician's evaluation is in order.
panel is in a laundry room with a clothes dryer, gas water heater, and gas furnace.
i wonder if this occured sometime during the last 10 winters. 1996 home.
warm and toasty inside...10 degrees outside.
Old 6/7/07, 10:02 PM
cwillick1 cwillick1 is offline
laundry rooms create moisture that panel is not air tight. i would suspect the moisture is settling inside the panel
Old 6/7/07, 10:08 PM
Banned
Yeah, probably the nipple needs sealed to prevent air transfer.
Old 6/7/07, 10:48 PM
Carl A. Brown's Avatar
Maybe it is because the meter cans are not flashed on the out side!
Old 6/8/07, 1:19 PM
gnovian gnovian is offline
I would recommend it be further evaluated by a licensed electrician.
Old 6/8/07, 2:30 PM
You should really be sealing any raceway that passes from inside to outside. People usually get away with it but you do have the possibility of drawing moisture in from outside to condense or cold air that condenses the moisture on the inside, depending on season.
This is covered in 300.7
Old 6/8/07, 2:35 PM
Paul W. Abernathy's Avatar
here ya go Greg.......300.7 for them to view...
300.7 Raceways Exposed to Different Temperatures.
(A) Sealing.
Where portions of a cable, raceway, or sleeve
are known to be subjected to different temperatures and
where condensation is known to be a problem, as in cold
storage areas of buildings or where passing from the interior
to the exterior of a building, the raceway or sleeve shall
be
filled with an approved material to prevent the circulation
of warm air to a colder section of the raceway or
sleeve. An explosionproof seal shall not be required for this
purpose.
Paul W. Abernathy,CMI,CPI,CME
Old 6/8/07, 5:29 PM
This effect is also why a perfectly sealed (all water tight pipe joints) underground raceway will eventually collect water. Thermal cycling pulls moisture in and it condenses in the cool ground.
You should probably be using duct seal in them too if you wanted it dry but nobody does. You need wet location wiring anyway.
National Electrical Code Information and Discussion jtedesco1 Electrical Inspections 50 6/15/10 8:28 PM
Moisture in slabs mcyr Structural Inspections 7 8/20/07 8:33 PM
bbbb mcyr Structural Inspections 1 8/19/07 11:26 PM
Moisture control for slab on grade in protecting floor finishes mcyr General Inspection Discussion 2 8/13/07 8:53 PM
Bad electrical problem Pest Guy Electrical Inspections 4 1/20/06 10:26 PM
