Old 12/14/09, 12:38 PM
Peter W. Bennett Peter W. Bennett is offline
Default Mounting of Panel
Any code reference to mounting a panel on concrete block vs plywood?
Find an InterNACHI certified North Carolina Home Inspector (and anywhere else in North America)
Old 12/14/09, 5:47 PM
Jim Port Jim Port is offline
Unmoderated Guest
Default Re: Mounting of Panel
No problem.
Old 12/15/09, 10:21 AM
Jeffrey R. Jonas's Avatar
Check with your AHJ... a town in my area requires the panel be attached to "treated plywood/lumber" prior to mounting to block/stone/brick/concrete.
Old 12/15/09, 9:06 PM
Just remember a few things....if this was a Damp or Wet Location ( and I am not saying it is...I'm just saying ) then you would need to be aware of 312.2 as well which would require the 1/4" airspace.
Otherwise, just check your local AHJ for any localized mounting surface requirements.
Paul W. Abernathy
National Electrical Code Information and Discussion jtedesco1 Electrical Inspections 50 6/15/10 7:28 PM
Electrical for Dummies mcyr Electrical Inspections 16 6/9/08 9:59 PM
Panel Inspection Safety roconnor Electrical Inspections 10 9/24/06 9:02 PM
