http://www.dli.mn.gov/ccld/PDF/eli_GFCI_history.pdf
The origins of the twist-on wire connector are obscure, but references to their use can be found since the early 1920’s. Originally called "porcelain connectors," twist-on connectors are often referred to by the industry name "wire-nut®," which has been the trademark of Ideal Industries since 1939. The early twist-on connectors were made of porcelain and similar inorganic materials, and did not contain an inner spring (see Fig. 12). By 1930 plastic Bakelite connectors were beginning to appear, and by the 1940’s inner springs were added to better twist and more securely capture the conductors. By the late1960’s thermoplastic (nylon, polypropylene, etc.) twist-on connectors were becoming common, and aluminum wire combinations were added to accommodate the increased use of aluminum wire. In the mid-1980’s, enhanced requirements were added to the -Roycooke@hotmail.com I prefer E-mail Roy Cooke UE mlarson is on my ignore list "All that is necessary for the triumph of evil is that good men do nothing"----- - -Edmund Burk |
| Need a home inspection in Nebraska? Check out InterNACHI's listing of Nebraska certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Thank you Roy. Good reading..
Bert |
I had never seen or heard of the wood base moulding type of wiring. Very interesting.
Thanks for the link! David Hays All Points Home Inspections LLC Denver, CO 720-670-0366 allpointshomeinspect@yahoo.com www.allpointshomeinspections.org |
Any time I see the old cloth cover I recommend replacement .
| An interesting electrical service set up. | smick | Miscellaneous Discussion for Inspectors | 5 | 1/25/13 12:06 PM |
| Coming to Schaumburg, Ill - Electrical Training with The Electrical Guru | ksitzes | Inspection Education & Training | 12 | 3/17/10 4:19 PM |
| Operating a Switch or Breaker Handle | jtedesco1 | Electrical Inspections | 7 | 12/21/07 1:49 PM |
| Free! NACHI Chapter Electrical Inspection Seminars | jtedesco1 | Inspection Education & Training | 0 | 10/2/06 4:40 PM |
| Wired for Safety Video | jtedesco1 | Electrical Inspections | 0 | 1/4/06 6:31 AM |
