How much time do you spend inspecting the electrical system in a one family home built before 1980? Did you ever encounter a situation similar this this one?
Usuallly when I see them they are in the skeletal state.
This guy was such a sound sleeper, he never woke up.
Scott Schultz is a non-member guest and is in no way affiliated with InterNACHI or its members.
For me, the time is the same regardless of when it was built. I always look for the same things on every panel....the only things I do differently is look for solid alum. wire in older panels as opposed to the newer ones. But, checking for proper wire size, double taps, neutral connections, etc...is a constant on all panels so the time doesn't really differ.
Seen it many times.
A good reason to ensure the knock outs are capped and panel cover secure. |
| Digital Camera Recycle Time | afrost | General Inspection Discussion | 30 | 6/7/07 11:53 AM |
| Heat Pump Check list for inspecting | dmacy | Inspecting HVAC Systems | 22 | 2/1/06 12:56 PM |
