Is this ok? Poco tag still intact. Thoughts/comments?
Thanks in advance! |
| Need a home inspection in South Carolina? Check out InterNACHI's listing of South Carolina certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Since the three SE cables are going in different directions it would likely be impossible to comply with NEC 230.72. Also I don't see how those three cables could legally be connected at the load side of the meter.
NOTE: There were two 6o amp fused disconnects in basement. Other feed to large barn.
What is behind that meter is not the HI concern. It is not accessible.
That gas regulator vent may be too close though... "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
What is poco? I too would expect that the connections in the meter base are not to code and then would be a fire/safety hazard. I can see that the cables are not secured to the bldg. If an inspector passed it with these defects, something is wrong in Columbus, OH. I have heard stories in the past 1.5 years about leadership.
Bill Stenger master electrician/licensed elec inspector (oh,KY) certi. bldg inspector (I.C.C.) |
POCO - power company.
| Electrical Meter gadget? | dvalley | Electrical Inspections | 6 | 10/31/08 3:49 PM |
| Dwelling and Commercial Electrical Equipment | jtedesco1 | Electrical Inspections | 4 | 1/10/08 6:46 AM |
| Electrical Safety Principles | pabernathy | Electrical Inspections | 8 | 1/1/07 1:13 PM |
