| Electrical Contains discussions about electrical systems. This includes outlets, panels, wiring, et cetera. |
LinkBack | Thread Tools | Display Modes |
I know that having both breakers on the same bus is wrong, but I'm not sure how to spot it. Can anyone give me some pointers or maybe post a photo. Thanks.
Mike Whitt is a non-member guest and is in no way affiliated with InterNACHI or its members.
The breakers should be beside each other and not just anywhere in the panel
Many panels are different.
FPE and GE for instance if skinny breakers are used they can be one on top of the other and still be on the same phase. Move them one half space up or down and they are on opposite phases. This can even happen with some two-pole skinny breakers. Pushmatic/Bulldog are always side by side. The two buss rails run down the whole length of the panel. Phase A runs down the left side of the panel and phase B runs down the right side. Unfortunately there is no simple answer to your question, other than to check with a meter. |
In fuse panel, the hot wires should be on opposite sides of a 2 fuse holder set up. In Canada, when supplying a split receptacle, you must use a double pole breaker. |
Look at the diagram of a panel, without the breakers and you will get the idea John.
Being basic , remember there are two hots and you need both contacts drawing energy from (not the same one) Chicago Home and Condo Inspection Chicago Condo Inspection Chicago Home Inspection Chicago Home Inspector Bob Elliott Home Inspection Software by Home Inspector Pro Chicago Home Inspection Information Homeandcondoinspector.com Homeandcondoinspection.com protection of people and property |
Thanks guys.
Try this
badair http://www.adairinspection.com 972-487-5634 Dallas & Garland, TX 75228 & 75042 Residential-Commercial-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 04080595 Voted, by a slim margin, InterNACHI U.S. Member of the Year 2008 life is the random lottery of events followed by numerous narrow escapes...accept the good http://www.gunlaws.com/images/unitys.gif |
Thanks Barry. That's very helpfull. I understand the concept but it seems from Speedy's post above that you have to know your way around the various panels (i.e. be a current or former electrician) to accurately call out this problem.
I don't feel confident I can do this yet so I'd better leave it alone. |
| Display Modes | |
| "UFER" Ground? see last paragraph. | jtedesco1 | Electrical | 6 | 9/15/08 8:57 AM |
| What's this video worth? | jtedesco1 | Education | 5 | 4/18/08 10:24 AM |
| Nice Report on AL Wire Terminations - Enjoy | pabernathy | Electrical | 0 | 7/2/07 1:35 PM |
| Proper Marr Connectors for Aluminum Pigtails | jskrypka | Canadian Inspectors | 4 | 3/25/07 11:41 PM |
