Old 7/16/10, 1:28 PM
Jeffrey R. Pope's Avatar
Default Multi-wire Circuits
NEC 210.4 (B) Devices or Equipment. Where a multiwire branch circuit supplies more than one device or equipment on the same yoke, a means shall be provided to disconnect simultaneously all ungrounded conductors supplying those devices or equipment at the point where the branch circuit originates.
A multi-wire circuit is serving a living area of a home. One branch serves the receptacle outlets, while the other serves the lighting outlets.
Question - Are the breakers required to be tied together for simultaneous shutoff?
Please qualify your answer.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Need a home inspection in Massachusetts? Check out InterNACHI's listing of Massachusetts certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/16/10, 2:20 PM
Bruce A. King's Avatar
Default Re: Multi-wire Circuits
I read a discussion on Mike Holt's forum once where someone said the 2002 code actually required the handle tie when outlets were on the multi wire branch circuits. The 2008 code then included devices and equipment as part of the handle tie requirement.
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Old 7/16/10, 3:56 PM
The question is, what is your definition of "equipment on the same yoke?" I generally define "yoke" as a device or piece of equipment contained in a single "space" or enclosure - such as a multi-wire circuit powering a single duplex receptacle.
My interpretation is that there is no need for a handle tie in the instance I described, as these are not "on the same yoke."
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 7/16/10, 4:15 PM
No requirement for a handle-tie, until a house is built under the 2008 NEC adoption that requires a MWC to include a handle-tie.
Jeff
Jeff Wicklander
Corwick Home Services
Join my business on Facebook
Old 7/16/10, 4:17 PM
CA is currently using the 2005 NEC. Can you post the 2008 section?
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 7/16/10, 4:20 PM
I did see that mentioned in lots of discussions, a yoke is simply the strap on an outlet or switch body used to mount it.
Some "experts" are posting on the web that ALL multiwire circuits must have handle ties or be a dedicated double pole breaker based on the 2008 code.
Here is a good article.....
http://www.ecmag.com/?fa=article&articleID=8741
704 301-3207
Old 7/16/10, 4:25 PM
Good article - thanks Bruce.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 7/16/10, 6:37 PM
Chuck Evans's Avatar
That is consistent with the way that I have always treated it. If they are connected separately to a single duplex receptacle or stacked switches on the same yoke - yes; separate outlets and switches - no. I consider whether someone can safely work on one circuit and not be endangered by the other. Though the shared grounded conductor may present a potential issue.
Chuck Evans (TREC #7657)
Houston Home Inspector
Houston, TX
Old 7/16/10, 6:40 PM
Jim Port Jim Port is offline
Unmoderated Guest
This is the reason the the 08 NEC now requires a 2 pole breaker for MWBCs.
Old 7/16/10, 9:45 PM
Robert Meier's Avatar
All multi-wire branch circuits require simultaneous disconnect (multi-pole CB or handle tie) under the 2008 NEC. This requirement was actually in the 2005 NEC {605.7} but only applied to freestanding type furniture partitions, and as mentioned MWBC's on the same yoke.
Here's the 2008:
210.4 Multiwire Branch Circuits.
(A) General. Branch circuits recognized by this article shall be permitted as multiwire circuits. A multiwire circuit shall be permitted to be considered as multiple circuits. All conductors of a multiwire branch circuit shall originate from the same panelboard or similar distribution equipment.
FPN: A 3-phase, 4-wire, wye-connected power system used to supply power to nonlinear loads may necessitate that the power system design allow for the possibility of high harmonic currents on the neutral conductor.
(B) Disconnecting Means. Each multiwire branch circuit shall be provided with a means that will simultaneously disconnect all ungrounded conductors at the point where the branch circuit originates.
Evaluating your home's wiring system mcyr Electrical Inspections 0 12/30/09 1:31 PM
Multi Wire Circuits jallingham Electrical Inspections 7 10/15/08 2:18 PM
What's this video worth? jtedesco1 Inspection Education & Training 5 4/18/08 9:24 AM
Nice Report on AL Wire Terminations - Enjoy pabernathy Electrical Inspections 0 7/2/07 12:35 PM
