Old 8/27/09, 11:25 AM
Joe Funderburk, CMI's Avatar
Default Multi-wire circuits: no handle ties
Do you write that up as a defect? Example: dishwasher and garbage disposal share the same grounded (neutral) conductor. This is a common wiring practice
If you don't, I'd recommend it. Here's the hazard: you need to change the garbage disposal. You flip its breaker off. You're working on the neutral conductor and someone turns on the dishwasher. The neutral is now a current carrying conductor. Ouch! Begin to curse wife!
Photo below: 2 lower breakers serve 2 kitchen appliances. One neutral.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Find an InterNACHI certified Connecticut Home Inspector (and anywhere else in North America)
Old 8/27/09, 2:27 PM
Jim Port Jim Port is offline
Unmoderated Guest
Default Re: Multi-wire circuits: no handle ties
Prior to the 08 NEC there was no requirement for a handle tie on MWBCs unless in commercial settings or on the same yoke. This is now required whenever MWBCs are used along with the conductors of the MWBC to be grouped together in the panel.
Old 8/27/09, 2:55 PM
Unmoderated Guest
I forgot to add in my other post that the neutral was required to be pigtailed. You could not use the device to splice the neutral in the MWBC.
Old 8/27/09, 10:15 PM
Won't mention anything about it unless the house was built while the jurisdiction was under 2008 code.
Jeff
Jeff Wicklander
Corwick Home Services
Join my business on Facebook
Old 8/27/09, 10:33 PM
Mark E. Northrup's Avatar
Mark E. Northrup Mark E. Northrup is offline
Joe I was wondering how you know that they are sharing a neutral. From the pic i see a red wire and a black wire. but cannot see how they share a neutral. Thanks
Mark
House 2 Home LLC
503-602-1420
HomePros@House2HomeLLC.ORG
Protecting Peace of Mind One House at a Time
IAC2 Certified
IR Certified
A favorite place on Google Maps
Old 8/27/09, 10:48 PM
If romex was run, it would be pretty simple to tell. Two hots in the jacket along with a single neutral coming out of the panel. If it was run in pipe, they may be the only three wires running in the pipe.
Jeff
Jeff Wicklander
Mark
Count the 15/20 amp breakers and count the neutrals. They should be equal in number. In this case, there was one more breaker than there were neutrals. A scan of the incoming wires revealed that this one was a 3 conductor + ground.
Theodore Roosevelt
Joe Funderburk, CMI
Old 8/27/09, 10:50 PM
Jeff
I wrote it up as a recommended upgrade. It's a safety hazard, same as the lack of a GFCI, no matter the age of the home.
Theodore Roosevelt
Joe Funderburk, CMI
Old 8/27/09, 10:52 PM
I don't consider it a safety hazard. It's a very commonly applied and accepted work practice.
Jeff
Jeff Wicklander
Old 8/27/09, 11:34 PM
Jeff
So, then, what is the purpose of the handle tie in today's code?
Theodore Roosevelt
Joe Funderburk, CMI
Old 8/27/09, 11:39 PM
The NEC is starting to become a babysitting service because of the unqualified personnel that think they know how to work on electrical. Do you recommend every client to upgrade all their receptacles to be tamper proof as required?
Jeff
Jeff Wicklander
Old 8/28/09, 12:08 AM
Bruce A. King's Avatar
The handle ties are needed on 240V loads so that both breaker sections trip if the load is excessive on just one leg.
The disposal and d/w are just 120V loads so there is no reason to trip both breakers if one draws too much.
As far as I know, the situation in the original post is considered acceptable since "only electricians should be working with the wiring".
I was installing a ceiling fan once and the power company guy came to turn off the power to the house so I was just working away and got fried because of two reasons. He turned it back on within 10 minutes without coming back to the door to warn me even after I told him what I was doing and voltage was still at the fixture with the switch off to a crappy wiring technique called "switched neutrals".
Maybe someone has the code history on switched neutrals (thread drift here), I don't think they are allowed anymore but once were allowed.
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Old 8/28/09, 12:09 AM
Only electricians install garbage disposals?
Theodore Roosevelt
Joe Funderburk, CMI
Old 8/28/09, 12:24 AM
If that was the case i would be out of work. And home depot would not sell disposals.
I agree with you on the neutral though. It would be a safety concern.
House 2 Home LLC
503-602-1420
IAC2 Certified
IR Certified
Old 8/28/09, 12:28 AM
Anyone can install one, just some get shocked in the process.
I have to admit, I never thought of that scenario.
I did a reinspect once where they still had not tightened a panel lug, the builder called the electrician and the owner of this fairly large company was in the area so he came right over to fix it. I watched this guy, he probably had 30 years experience, he turned off the main breaker and pulled out a big allen wrench (non insulated type) and started to tighten the lug and stopped. He put the tool in his pocket and walked about 60 feet to the truck and came back with a voltmeter and made sure the power was off and then proceeded. I was thinking, yep, he has seen some weird wiring problems and was not ready to take a chance that day.
704 301-3207
GFCIs on 2 wire circuits dscott2 Electrical Inspections 10 4/4/09 2:41 PM
Multi Wire Circuits jallingham Electrical Inspections 7 10/15/08 2:18 PM
What's this video worth? jtedesco1 Inspection Education & Training 5 4/18/08 9:24 AM
Nice Report on AL Wire Terminations - Enjoy pabernathy Electrical Inspections 0 7/2/07 12:35 PM
