Petery is a non-member guest and is in no way affiliated with InterNACHI or its members.
I'm moving out of state to an older 1983 trailer house, but I have a couple of questions on things that may or may not be wrong with the electrical system
1. Bryant Breaker Panel (I Do not know if these panel's have a bad rep Like FPE or Zinsco) 2. All Breakers are double type (I guess to save for future expansion's since it's a small panel?) 3. Almost all receptacles are painted over (I can always replace them latter though as I think I will have to anyway because most of them could barely hold in a Nightlight, plus alot of cover plates are missing from the devices 4. Unknown Junction Box Without a Cover High On the wall (I believe it was for a smoke detector as in the rest of the place thats where they are mounted and it has a molex plug attached on it Like the detachable plug for smoke Detectors) I do not know if there is a third wire in the box yet. The smoke detectors are original to the place so I planned on replacing them any way with another set of hardwired units (Any Brand Recommendations? Firex Kidde, BRK , Etc any one have interconnected ones with a built in co2 Detectors 5. GFCI Outlet are installed in the kitchen and bathroom and function properly I did not notice a GFCI outlet any where outside However I did not trip the kitchen or bathroom outlet and then go and test the outside outlets so I would need to install a GFCI for all out door outlets 6. I will have a shed an plan I using the outlets to power stuff in the shed (It is only 20FT from the Trailer house So a 10 Gauge extension cord should be fine? (4 FT Shop Lite 40W Soldering iron, Radio, Fan (I will Never Run a space heater or an AC Unit) Just what I mentioned and maybe a 2 AMP Rotary Tool or a 4 AMP Jigsaw) 7. Dryer Outlet is only a 3 pronger and the one in my current apartment is a 4 pronger and the dryer currently has a 4 prong plug. The dryer when originally bought new came with no power cord and I had to buy I 4 Prong Power cord So I just buy a new cord and attach correct and then do the bonding jumper for neutral to frame. My Step dads electrician friend has a whole bunch of 10-3 left over from a job that he did and he said he would install a dryer 4 prong dyrer outlet (Panel is only about 15-20 FT away and outlet is surface mounted) Will the breaker change? or just the wire and receptacle? It currently has a 30 amp breaker Thats all I can think of for now and sorry for the long post http://images.dr3vil.com//files3/22/.../mainpanel.jpg http://images.dr3vil.com//files3/22/...rhome/jbox.jpg http://images.dr3vil.com//files3/22/...Spec_Sheet.jpg (Warning Large Picture) |
Roy Cooke Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
| Inspector listings by county | rcarter | Miscellaneous Discussion for Inspectors | 8 | 8/22/09 10:40 AM |
| California Home Inspections | whandley | Miscellaneous Discussion for Inspectors | 17 | 6/4/08 12:28 AM |
| Electrical Safety Foundation International Links | jtedesco1 | Electrical Inspections | 5 | 12/8/07 3:10 PM |
| Mould inspection saves the day! | gmendes | Canadian Inspectors | 43 | 11/18/06 10:51 AM |
| Home Inspector Listings Part Two | jbowman | Miscellaneous Discussion for Inspectors | 8 | 8/29/06 8:52 PM |
