Nothing really "wrong" here, but you were asking for it. . .
The top bus bar is a bit warmer than the lower, but nothing I considered abnormal. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
121?...no of course she's fine.... I think the hottest breaker I scanned (found) with the IR Therm. was 190......
Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
It looks like the insulated conductors are touching the live bus. That's not good.
BestInspectors.Net
& Real Estate Training Academy Inspection Report Software for Windows - iOS - Mac - Android Continuing Education Home and Commercial Building Inspection - Skilled Trades – Real Estate – Appraisal – NFPA 921 http://www.bestinspectors.net est. 1992 |
What's considered a "normal", and what's considered "excessive" for the temerature range?
That's a difficult question to answer Mark.
Temperatures of 150 and below don't usually get my attention, but it really depends on other factors as well. When there is discoloration to the breaker, wire, terminal or bus bar, regardless of the temps, there is something "not right." A high temp reading (IMHO) should generally be considered as a means to "confirm" a problem, rather than to "diagnose" a problem. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Jeff;
Pardon my French, but would not a 40 amp breaker drawing 30 to 35 amps at the time you took the camera shot explain why the temp. reading is such as it was? Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
That was the circuit for the condensing unit of the A/C after about 15 minutes of operation. The house was vacant, so no other circuits were in operation at that time (except the FAU).
Jeff, Did you move your position with the camera to determine whether it was a heat related problem or a reflection?
Yep. I always look from several different angles.
I don't know about this one you guys!
I think you should change the emissivity setting in your software and see what that low emissive bar is actually kicking out there! I understand that this is a hot panel, but the temps your camera is showing is for 97% emissivity? What happens at 23%? Aluminum is from .10 -.40 depending how corroded it is. That bar could be from 250-300 degrees F. |
Sacraficing "unused" body parts. You are a righty, right? ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
Big B...... Hey...I bet Nick a years salary he didn't land a couple hundred thousand foreclosure inspections, so I'm down to body parts until Nick PAYS up..!!!.................. http://www.nachi.org/forum/showthrea...nd+foreclosure ...................................... Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
My digital thermometer read 120 degrees, which is awful close to what the BCAM shows. I don't consider this to be abnormal by any means.
I'm still a beginner with my BCAM, but I have a little experience with the rest of my tool box, and I'm certainly no stranger to likes of Zinsco. . . IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
| sewer smell only in the AM (posted by Buddy Moore) | AskNACHI.org | AskNACHI.org Inspection Questions Forum | 7 | 9/26/07 6:20 PM |
| Exclusively for Dale Duffy | jpope | Electrical Inspections | 11 | 11/30/06 9:01 PM |
| Hey Buddy, Nice Flat Roof | psmothers | Exterior Inspections | 3 | 4/29/06 12:10 AM |
