Old 12/29/12, 5:28 PM
Mark A. Timpani, CMI's Avatar
Mark A. Timpani, CMI Mark A. Timpani, CMI is online now
Default my house, my question
I pulled out an old spa from the exterior. The old electric box is now capped off with the old spa motor 30a wires tucked away in it. Can I/how do I install a GFCI outet there? I figured, why waste it, the wires are ran already and I could use an outlet on the patio... Thank you for your help.
"Be Proud of Your Home, Go With Pride!"
'Not just a Home Inspection, but an Education'
Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties.
Need a home inspection in Maryland? Check out InterNACHI's listing of Maryland certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/29/12, 5:39 PM
Stephen W. Stanczyk's Avatar
Default Re: my house, my question
If it were me, I would add an exterior box on one side of the spa box for your receptacles (4) and another box on the other side with an outdoor switch for future added lighting, fountain, pond, storage shed or whatever. Do all the wiring at once and put a lock on the spa / new junction box.
Stephen Stanczyk
Old 12/29/12, 5:47 PM
Robert Meier's Avatar
Install a WP/TR GFCI receptacle with a wet location in-use style cover. Change the 2P-30 CB to a single pole 20, land the white conductor on the neutral bar.
Old 12/29/12, 7:03 PM
James F. McKee's Avatar
You're stuck Mark ...you have to buy a new spa, that is all there is to it...You have the outlet ..You must have a spa...no exceptions....
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
440 225 8688
Old 12/29/12, 7:37 PM
Jeffrey R. Pope's Avatar
Or change the breaker out to a single-pole, GFCI type...
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 12/29/12, 9:00 PM
William Blackmon's Avatar
William Blackmon William Blackmon is offline
Just be very cautious when you connect solid #10 wire to a receptacle. It is very easy to accidentally place considerable stress on the receptacle body when installing it in the outlet box and damage the receptacle, whether it is a standard duplex or a GFCI.
If in doubt, install a properly sized box and make pigtails to the receptacle, ensuring that you use the appropriate size wire based on the new OCPD you install in the panel for this circuit.
Licensed Master Electrician, Kentucky #ME 6509
PHII Certified Inspector,#LMH30000017878
EPA Universal Certification Section 608, #0028673113930
Member, National Fire Protection Association
"Give me six hours to chop down a tree and I will spend the first four sharpening the axe." Abraham Lincoln
Old 12/29/12, 10:26 PM
Yes I agree that would work too, but then you would still need to find a listed weather-resistant receptacle.
Old 12/30/12, 5:52 PM
That is what I was wondering about William. The large size wire to a 110 GFCI outlet..
Old 12/30/12, 6:17 PM
A standard 15 or 20 amp, 120 volt GFCI receptacle will accept #10 conductors. You cold always tail off with smaller conductors based on the size of the OCPD.
Old 12/30/12, 7:35 PM
Yes, they are indeed rated for #10, but I am certain you are like I and have seen a fair amount of broken receptacles when installers forced the device back into the wall.
It is very difficult for most individuals who have not installed many devices to land #10 solid and get it back into the box with the correct amount of minimum conductor length.
Please review my new article wdecker General Inspection Discussion 8 12/10/11 2:05 PM
Old house finished ceiling question jrudy Interior Inspections 9 9/18/11 12:09 AM
Coming soon. Free, online, fireplace and chimney inspection course. gromicko General Inspection Discussion 15 12/14/09 4:19 PM
Question for house inspector (posted by Kim Chan) AskNACHI.org AskNACHI.org Inspection Questions Forum 18 6/17/07 11:56 AM
