Hello all, this box had more than six throws with no main disconect. Is there a name for the breaker type in the upper left corner of the picture.
thanks Joe Joe Kormos A-1st Look Home Inspectors Inc. 630-201-0933 Your 1st Choice in Property Inspection Professionals www.a-1stlookhomeinspectors.com www.a-1stlook.com Let us look before you buy...for peace of mind “Thinking is the hardest work there is, that’s why so few engage in it. ” Henry Ford |
tneyedli1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Bland and faceless. T.Neyedli www.alphahomeinspections.ca |
That IS the main. The screw in the center is the required retention device
Ok but no throw switch on it for disconnect
It's not a main or even a breaker.
If used for incoming power it is a main lug conversion device, or for out going power it is a feed-through device. There is NO switch in that unit. In this case it is a factory installed main lug kit. |
Joe,
Is that a Cutler-Hammer panel? ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
The 2 devices are separate electrician installed and the non approved self tapping drywall framing screw securing them is not factory equipment, either an idiot sparky or Homer installed that.
Now what is the name for the "main lug conversion device" or "feed-through device" SUB-FEED LUG BLOCK ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good Last edited by badair; 2/17/07 at 8:49 AM.. |
That's not a drywall screw holding that subfeed lug adaptor in place. That's the washer head screw that CutlerHammer provides in the adaptor kit, in a little manilla envelope, for that purpose.
Thanks for that correction. Now who's the idiot? ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
I'm very sorry, Barry. It wasn't my intention to do that. Here's the .PDF for that lug block kit, which details the screw. http://www.eatonelectrical.com/unsec.../PUB24021B.PDF
Ahh.....help me out here.....but this looks indeed like a Main Lug Kit...but is this a Main Distribution Panel....and if so....it should have a Main Disconnect within it based on the posters comments.
Unless it is a Sub-Panel or has a Service Disconnect out beside the meter enclosure.......otherwise it would need that breaker to be a OCPD and not simply a MLO Kit. if this is the case.......proper call Joseph and should be the issue.....I notice all the "Grounded" conductors on the left rather neat so thats why I had to ask...is it a Main Panel or a Sub-Panel....if it is a main panel and no disconnect ahead of it at the meter...then it is wrong. Paul W. Abernathy |
Good morning all, yes it is a Culter Hammer box, 2 year old condo, no sign of handy home home owner, this is the main panel, no main disconnect in the unit. I could not find a configuration like this on the Eaton web site. So having more than 6 throws to deenergize the system was my flag, I just don't know what to call the device.
The main disconnect could be at the meter, but I did not have access to the area where the meters where located.
I know what I saw when I looked in the mirror after I read your reply. I try not to expose it publicly, too often. It is better to remain silent and be thought a fool than to open one's mouth and remove all doubt. Abraham Lincoln If I can't laugh at myself... Keep up the great work, my brother! ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
Condo? That's what makes me think it's a subpanel even more. Generally, condo's have a meter stack someplece, with the tennant breakers in the meter stack. Sometimes, the tennant breaker can be disguised by a cover that looks pretty mundane. Do you have any pictures of the meter configuration for that unit? The metering equipment can be on the outside of the building, or in a metering room inside the condo building.
| AFCI Questions and Answers - Mike Holt | pabernathy | Electrical Inspections | 7 | 4/16/12 9:51 PM |
| Electrical Guru Question? Breaker lock outs | pdoane | Electrical Inspections | 4 | 9/7/07 2:05 PM |
| Double Tapped Breaker | tjohnson3 | Electrical Inspections | 8 | 4/20/07 9:04 AM |
| Massachusetts Board of Registration of Home Inspectors | jtedesco1 | Legislation, Licensing & Legal Issues for Inspectors | 0 | 2/14/06 3:38 AM |
