Old 9/9/09, 8:25 PM
William J. Decker's Avatar
Default Name that defect? Care to play?
I will send an $25.00 check to the first person who can identify this electrical panel defect.
1931 apartment conversion condo building. Milbank multiple unit panes in the basement commojn area (Picture 1).
Now, here is the question:
Look at picture 2. Inside of the subject unit's panel. What is the major defect.
Hint 1: In Illinois, inspectors, are required to call out, as "significantly deficient" items that are unsafe. From the state SOP administratibe rules:
"Unsafe: A condition in a system or component that is a significant risk of personal injury or property damage during normal, day-to-day use. The risk may be due to damage, deterioration, improper installation or a change in accepted residential construction standards."
Hint 2: NEC 2008 is the current accepted residential construction standards.
Hint 3: Yeah, I know that the panel was not properly labeled as to branch circuits. That is not the defect I mean.
To gain the prize, name the defect AND site the NEC 2008 code section.
Good Luck. I will contact the winner and send him (or her) the check. I will not, right away, post who that winner is in the interest my messing with meany other people's minds and promoting discussion, argument and the good old give and take excahnge that this board is noted for.
You may begin.
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Find an InterNACHI certified Utah Home Inspector (and anywhere else in North America)
Old 9/9/09, 8:39 PM
Bruce M. Graham, III's Avatar
Bruce M. Graham, III Bruce M. Graham, III is offline
Default Re: Name that defect? Care to play?
panel could have more than 6 throws.
Bungalows to Mansions
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 9/9/09, 8:45 PM
Mark E. Northrup's Avatar
Mark E. Northrup Mark E. Northrup is offline
Where's the ground lug?
House 2 Home LLC
503-602-1420
HomePros@House2HomeLLC.ORG
Protecting Peace of Mind One House at a Time
IAC2 Certified
IR Certified
A favorite place on Google Maps
Old 9/9/09, 8:48 PM
Distrobution panel. Neutral is floated (around here, everything is required to be in conduit, which carries the ground.
The six throw rule is OK. Six throws means six "hand throws", not six switches. My hands are pretty big.
No joy yet.
Any other players.
Final hint. Look at picture #2. It is right there before you and deals with a change in the 2008 NEC.
Now get to it
Will Decker, CMI
Old 9/9/09, 8:52 PM
Multi wire circuits, the 2 ungrounded conductors should be tied together and on seperate phase. The box should have 3 double pole breakers.
Bruce M. Graham III
352 871 8989
NACHI05091592
ICC 5268478
Old 9/9/09, 9:07 PM
Bob Elliott's Avatar
Biggest mistake would be applying 2008 NEC code to a grandfathered panel.
Ok looking back you mentioned rehab.
Assuming there is no Remote distribution panel I would if applying Code site lack of AFCI protection.
That would be my first issue if this is a recent rehab and electrical work was done ,as it needs to be brought up to code under those conditions..
Old 9/9/09, 9:12 PM
The only thing I can think of is...grouping the neutral with the appropriate multi-wire branch circuits (NEC 210.4d) and along with that the MWC branch circuit breakers must have a handle tie to disconnect both ungrounded conductors. (NEC 210.4b)
Jeff
Jeff Wicklander
Corwick Home Services
Join my business on Facebook
Old 9/9/09, 10:49 PM
Close.
Will Decker, CMI
Old 9/9/09, 10:52 PM
Picture is to fuzzy to tell much on that left side as far as the breakers are concerned.
Old 9/9/09, 10:57 PM
Christopher Currins's Avatar
Each multiwire branch circuit shall have a means to simultaneously disconnect all ungrounded conductors at the point where the branch circuit originates. That's not the case here.
Christopher Currins
Certified, Licensed
Proudly serving the Illinois Metro-East
Illinois Home Inspector
Top 5 Tasks for January
Old 9/9/09, 11:01 PM
Paul W. Abernathy's Avatar
poor dang breakers look like they have no ratings on them...are they simply disconnects and not the required Overcurrent protection?
I only see (3) grounded conductors.....how about
(D) Grouping.
The ungrounded and grounded conductors
of each multiwire branch circuit shall be grouped by wire
ties or similar means in at least one location within the
panelboard or other point of origination.
Exception: The requirement for grouping shall not apply if
the circuit enters from a cable or raceway unique to the
circuit that makes the grouping obvious.
and
(B) Disconnecting Means.
shall be provided with a means that will simultaneously
Paul W. Abernathy,CMI,CPI,CME
Old 9/9/09, 11:10 PM
Now when you say it is a distribution panel...i will assume their is a service disconnect somewhere upstream on all of these...otherwise i would expect a case to neutral connection at these panels also.....but you say it is a distribution panel so I wont venture down that path.
Old 9/9/09, 11:13 PM
Michael Roberson's Avatar
Michael Roberson Michael Roberson is offline
3 Neutrals, and 6 branch circuits. Possibly due to the change in the 2008 code concerning the neutrals making it all the way back to the distribution panel and not just tied together somewhere in the middle?
** Edit* Ah I see Paul said it more eloquently than I.
Old 9/10/09, 12:20 AM
lol...thats ok...someone was faster than I was at answering it correctly....but I posted the code...so I get extra points from the Deckster....
Old 9/10/09, 11:45 PM
So who's the winner Will?
Christopher Currins
Certified, Licensed
Congrat's Obama Jason1 Canadian Inspectors 80 11/13/08 8:49 PM
I Don't Care jstewart1 Miscellaneous Discussion for Inspectors 16 7/4/07 11:46 PM
