Old 8/8/10, 12:29 AM
Mark E. Northrup's Avatar
Mark E. Northrup Mark E. Northrup is offline
Default is it nec 2010 for a GFCI to be on a garage door opener
I have a electrician stating that it is a nec code for a garage opener to be on a GFCI outlet. Please state the code if this is true. House was remodled in 2008 and has multiple GFCI's in the garage almost all the outlets have one even if it is in the same run. Double tapping in the main service panel and two of the 15 amp breakers were over loaded with fans and bath ceiling heaters. IE turn them on and the breaker trips.
Thanks for your help
Mark
House 2 Home LLc.
House 2 Home LLC
503-602-1420
HomePros@House2HomeLLC.ORG
Protecting Peace of Mind One House at a Time
IAC2 Certified
IR Certified
A favorite place on Google Maps
Need a home inspection in Washington? Check out InterNACHI's listing of Washington certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 8/8/10, 12:49 AM
Bob Elliott's Avatar
Default Re: is it nec 2010 for a GFCI to be on a garage door opener
I have it as all general purpose receptacles must be GFCI.
Door opener is "dedicated" usually isn't it?
Old 8/8/10, 1:01 AM
That is what i thought and I wrote it up. But the Russian contractor states that it is NEC code. Which I have inspected lots of 2010 houses that have not had the garage door opener on a GFCI. this is a 1980 house that was remodled. And all the outlets in the garage except one had a GFCI on it. Some were in line with the string. So mulitiple GFCI's were used. Gives me the idea that someone didn't know what they were doing.
House 2 Home LLC
503-602-1420
IAC2 Certified
IR Certified
Old 8/8/10, 1:37 AM
Chuck Evans's Avatar
Mark
House 2 Home LLc.
Yes the sparky is correct. The 2008 NEC revision to article 210.8(A)(2) did away with the exceptions for dedicated outlets (e.g., freezers, irrigation controllers, etc.) and for inaccessible outlets such as those in the ceiling for garage door operators. Basically, if it's in the garage, it must be GFCI protected.
Chuck Evans (TREC #7657)
Houston Home Inspector
Houston, TX
Old 8/8/10, 1:39 AM
Joe Funderburk, CMI's Avatar
Who puts up a ladder to test an outlet in the ceiling anyway?
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 8/8/10, 2:08 AM
LOL. I disclaim checking GFCI for inaccessible outlets, however most of the newer construction that I do has the openers on the same device as the convenience outlets. When you trip the GFCI device the garage operator stops working, when you reset it, the light will typically come on. So its pretty easy to tell.
Houston, TX
Old 8/8/10, 7:14 AM
Robert Meier's Avatar
Yes Chuck is correct. This requirement changed in the 2008 NEC. That is unless you're in New Jersey where the State opted to keep the exception which IMO is a good idea. The 2008 would now require a sump pump receptacle to be GFCI protected. Given the possible consequences of a nuisance trip on a sump pump I like leaving the exception in the NEC.
One other point of interest, the new requirement under the 2008 only applies to 120 volt receptacles, a 240 volt receptacle would not require GFCI protection. I'm sure that when Chuck said "Basically, if it's in the garage, it must be GFCI protected" he meant only 120 volt receptacles.
Old 8/8/10, 8:03 PM
thanks for the info guys. And yes Joe F I check all outlets that are reachable. The one i don't will be the one that does not work.
House 2 Home LLC
503-602-1420
IAC2 Certified
IR Certified
Old 8/9/10, 8:42 PM
Brian E. Kelly's Avatar
the same guy who checks those fireplace outlets i suppose Joe.
Old 8/9/10, 9:43 PM
Bruce A. King's Avatar
So far all of the garage door outlets I have seen with GFI have the test/reset on the ceiling or a dedicated GFI device (no outlets) on the wall. These are independent of the regular garage outlet circuit. The code people should have required the reset to be within reach of a normal height person without standing on anything.
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Old 8/9/10, 10:20 PM
they make a special tool for those high ones Bruce, out here they call the special tool a "Stick".
Old 8/11/10, 12:54 AM
Tim Spargo's Avatar
Good point Bruce... "my outlet is compliant, but I broke my leg resetting it"
Tim Spargo
Spec Rite Inspections
661-317-5770
Old 8/11/10, 12:56 AM
If I see a reset in the ceiling, I write it up as "just plain stupid".
Theodore Roosevelt
Joe Funderburk, CMI
Old 8/11/10, 12:58 AM
And they come in right hand and left hand versions. I think Professional Equipment sells them.
Theodore Roosevelt
Joe Funderburk, CMI
attached garage ghelder General Inspection Discussion 5 2/23/10 5:40 PM
Garage door inspection procedure bgromicko General Inspection Discussion 5 8/7/09 12:47 PM
Installing GFCI in garage with no ground cyezza Electrical Inspections 53 11/30/07 5:05 PM
Garage GFCI rdale Electrical Inspections 29 8/8/07 4:06 PM
