jweinberg is a non-member guest and is in no way affiliated with InterNACHI or its members.
The data plate of this fairly new Exterior Trane A/C unit shows a minimum circuit ampacity of 17 Amps and is provided with a 12 AWG Cu (rated for 20 Amp) conductor connected to a 30 Amp breaker (unit disconnect also has 30 amp fuses).
I figure that this is so the breaker doesn't trip at start up each time. But the question I have is.....should the conductor be a 10 AWG Cu (for 30 amps) or is the 12 AWG CU considered okay since the start up surge is so short and unlikely to damage the 12 AWG Cu or create a fire hazard. My feeling is that the conductor is too small.....but wanted to check it out before submitting my report (later tonight) |
It is quite common to see a great disparity between the breaker ampacity and the wire gauge for AC compressor feeds. This is completely permissible. "Wire to the min, breaker to the max", are the limits of this rule when reading the dataplate. |
Very well put Thanks Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
I just noticed that this Trane dataplate also notes "min fuse or breaker size". That's something you seldom see noted on a dataplate. I suspect they do this to assure trouble-free future operation and not to mitigate any particular hazard. Usually it's just "min circuit ampacity", which relates to the wire gauge, and "max fuse or breaker size", which relates to the overcurrent protection size. Last edited by Marc D. Shunk; 1/21/08 at 11:48 PM.. |
BTW, down here duplicating it in Spanish would be a huge plus!! Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 Last edited by gbeaumont; 1/21/08 at 11:59 PM.. |
I've seen both min and max listed a lot but rarely have I seen them both listed at the same breaker size for both min and max. Figured this why there may be a need for 10 AWG. Thanks for your answer....I liked the quote....easy to remember. Gerry....are you claiming it as your quote originally? Thanks again... Jeff |
Congradulations guys this is the way a message board is suppp0se to work ask a question get an answer. I used to have a good friend and tool buddy that drove me crazy in a good sort of way you could ask him the time of day and he would tell you how to build a watch. Keep up the good work
Not every question has quite as straightforward of an answer as this one did. |
If you have the AC on more than the heat you probably want the vapor barrier on the top where the warm moist air usually is. |
I agree Marc as you do provide straight answers.
Pretty dry in San Jose California. Definately more furnace days than Air Cond days. Need A/C about 5-10 days per year. Furnace for 60-90 days/year. |
| Clarification of NACHI Conference in Toronto | rwand1 | Canadian Inspectors | 2 | 7/17/07 11:31 AM |
| Need a little clarification | rslocum | Electrical Inspections | 4 | 4/5/07 9:35 AM |
| Clarification on Safety Glass | jweinberg | General Inspection Discussion | 4 | 12/25/06 2:35 AM |
| need clarification on "laundry circuit" for new const. | bking | Electrical Inspections | 9 | 5/8/06 6:28 PM |
