Old 11/30/06, 9:51 PM
Ryan M. Kuenkel's Avatar
Ryan M. Kuenkel Ryan M. Kuenkel is offline
Default Need help with electrical Question??
My friend is currently upgrading his 100 Amp fuse box in our small house to a breaker box. There is, I believe, #4 copper or #2 Aluminum service from a 100 amp meter setting with a max 240 V meter. What is the highest amp breaker box he can go with? He needs 20 Spaces. Is an undersized service the hazard or oversized, or both? Any help on these questions would be wonderful.
Ryan Kuenkel
MHI Mission Home Inspection
www.mhi-inspection.com
Mason, Oh
NACHI06051563
Old 12/1/06, 3:17 AM
Darrell B. Hadler's Avatar
Darrell B. Hadler Darrell B. Hadler is offline
Default Re: Need help with electrical Question??
With the info from your post it is an undersized service that poses a hazard. The #4 copper would be too small for a 100 amp service. It should be at least a #3 copper. If it was a #2 aluminum, that would be ok for a 100 amp service. The panel itself is usually rated for 125 amps, but comes in many different sizes. They can hold 12, 16, 24, 32, 48, all the way up to 64 breakers depending on the brand you purchase. If the meter is only rated for 100 amps, that appears to be the smallest link in the chain, which would determine the maximum size of disconnect breaker it would allow. BUT...make sure its not a #4 copper supply as that would only be enough for a 70 amp system. It's always determined by the smallest rated link in the system, and does'nt matter if other components are rated higher than that.
I'm not the electrical wizard by any means, but this is how I understand it. I'm sure if I'm incorrect one of the specialized fellows will correct us.
Darrell Hadler CMI
Five Star Home Inspections
Medicine Hat, AB. Canada
NACHI# 04111082 Cell phone# (403)502-3593
Inspected once . . . inspected right!
Old 12/1/06, 8:03 AM
Unmoderated Guest
Darrell, the info you provided may be correct for Canada, but the OP is in the US so not all of it is accurate.
#4cu (or #2al) is standard issue for a 100 amp service in the US. ALso, our panels are limimited to 42 circuits/spaces.
Ryna, the largest panel you could install would be a 32 space Square D QO series. I don't know of anyone else who makes a 32 space or larger.
Typical would be a 20 space, or 20/24, or 24 space. Depending on what is available in your area.
Old 12/1/06, 8:08 AM
Michael Larson's Avatar
Petey,
Thanks for reminding us that CAN and US codes are similar but sometimes different in important areas for US inspectors.
A Green box for you my friend.
Old 12/2/06, 6:56 PM
Thank you for the information!! I will send this link to him!
So, Can he put a 125 amp breaker on the #2 al wire coming?? Thanks everyone. I love this NACHI family!
Ryan Kuenkel
Mason, Oh
NACHI06051563
Old 12/2/06, 7:59 PM
No, the # 2 AL is only rated for 100A ( 310.15.B.6 )...in order to place a 125A breaker on it ( if we are talking about the main breaker ) then it would need to be a 1/0 AL.. again if we are talking aluminum conductors.
Paul W. Abernathy
Old 12/2/06, 8:25 PM
Unmoderated Guest
What Paul said.
The panel may very well be rated at 125 amps, but the main breaker must be 100 (or less).
Download the videos here all about physics and electricity jtedesco1 Electrical Inspections 5 9/14/08 3:58 PM
DOE Handbook Electrical Safety pabernathy Electrical Inspections 2 1/1/07 5:33 PM
Handbook for Electrical Safety pabernathy Electrical Inspections 1 1/1/07 1:14 PM
POLL- Paul Stay In The Electrical Forum pabernathy Miscellaneous Discussion for Inspectors 40 12/19/06 11:05 AM
