Old 11/27/10, 2:18 AM
Timothy R. Wendorff Timothy R. Wendorff is offline
Default Need help identifying.
Picture #1: What's the point of the panel in the middle? The panel to the right does not appear to be grounded.
Picture #2: There is another circuit bypassing the fuse box (red wires going through to the panel on the right). Is this legal? How would you word this?
Thanks much.
Need a home inspection in New Mexico? Check out InterNACHI's listing of New Mexico certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/27/10, 2:26 AM
Dale Duffy's Avatar
Default Re: Need help identifying.
Thanks much.
I'd write the entire system is a MESS, have a electrician straighten it out as necessary.
And "legal" isn't a proper term for our type of business.
Old 11/27/10, 2:30 AM
Christopher Currins's Avatar
That pretty much sums it up.
Christopher Currins
Certified, Licensed
Old 11/27/10, 2:31 AM
I agree, I wouldn't put "legal" in a report. The main question would be, what's the best way to relay the information to the client.
Thanks.
Old 11/27/10, 2:39 AM
Bob Elliott's Avatar
Gosh ,no wonder you guys finish reports in half my time.
Old 11/27/10, 2:44 AM
Tim my word of advise would be to pick out some of the more major gaffs and document them.
Somehow just calling it a mess does not seem to be the correct verbiage.
In Illinois we are actually required to find the issue and a reason for the issue.
Great rule as it keeps you from slacking.
Did not scrutinize the pictures yet but I saw a few potential problems at a glance which is enough to suggest a Regular Sparky.
Whats with the two sets of panels and the meter.
Is this commercial or multi family?
Would be more concerned with the stone foundation if I was there however.
Place must be at least 100 years old I bet.
Old 11/27/10, 3:00 AM
The problem(s) discovered with the electrical service such as (********) and any other problems that an electrical contractor may discover while performing repairs need correcting. I recommend a reputable electrical contractor inspect further and correct as needed.
Christopher Currins
Certified, Licensed
Old 11/27/10, 3:06 AM
With only the view of these photos, the stone foundation is in better (safer) condition than the electrical service.
My home has a similar stone foundation, it ain't going anywhere.
Christopher Currins
Certified, Licensed
Old 11/27/10, 3:30 AM
Chris my issue with stone foundations is that people always figure they can flip a property for a profit by taming the basements with them into a "drywall and carpet" living area.
You are never going to waterproof them from the inside as far as I know.
People were not meant to live in these spaces when they were designed.
Exterior waterproofing is never going to happen if they are in the city because of the cost involved.
Old 11/27/10, 7:08 AM
Banned
Thanks much.
Can't see where the small wires from the devices in the middle panel go; they appear to go to the meter.....is this it? If so, the devices most likely are current sensing coils and are part of of an inside metering system. An older system that I have never seen yet!
A couple of months back, I was inspecting a 100+ year old 4 unit apartment building that had last been re-wired in 1959. The puchaser, looking to buy his first income property, had an electrical company on site to gather info for a complete update of the electrical. Each apartment had electric heat, electric stove and electric DHW served by 60 amp services and as such were served by coil driven "load shedding devices". The 2 young sparkies from the company had never seen "load sheddding" devices before; I had to explain how they worked!
Old 11/27/10, 7:55 AM
Robert Meier's Avatar
The large cabinet in the middle is a CT (current transformer) cabinet. The small conductors go to the meter.
Yes conductors are permitted to pass through a panel.
312.8 Enclosures for Switches or Overcurrent Devices.
Enclosures for switches or overcurrent devices shall not be used as junction boxes, auxiliary gutters, or raceways for conductors feeding through or tapping off to other switches or overcurrent devices, unless adequate space for this purpose is provided. The conductors shall not fill the wiring space at any cross section to more than 40 percent of the cross-sectional area of the space, and the conductors, splices, and taps shall not fill the wiring space at any cross section to more than 75 percent of the cross-sectional area of that space.
Old 11/28/10, 11:39 PM
Terry Clayton Terry Clayton is offline
If I am not wrong the small fused panel with the red wires may have been for a old water heater meter or maybe it is still in use was there 2 meters outside or maybe 1 and 1 that was blanked off.
Old 11/29/10, 1:31 AM
Dale Duffy's Avatar
When I see conductors dangling in the air above the panels, the one at the right wadded full, and everything else a mess, there is no sense in writing a book about it.
Have a licensed electrician make +++++ and any other repairs necessary so the electrical system is safe.
Short and sweet Condo......with out breaking into a sweat typing--
When I see piles of Fuses on the top of panels I have an idea there is usually "Other Issues" as well.
Old 11/29/10, 2:36 AM
OH Come on Dale
You know very well that those wires dangling are just regular phone wires that are connected into those punch blocks mounted above the panels and directly above all those loose expired bulbs being collected for some mysterious reason.I think they are there to fall in case some inspector gets to nosy.(booby trap).
As far as the number of wires in the right hand box goes we first need to know how many above permissible levels they are packed in if it all.
Now if you are referring to the fact that Romex-(is what you call that extension cord in the rest of the country right)?,then I agree it needs to be secured.
Is it with in 2 feet?.Sorry I do not get to practice my extension cord knowledge much.
See you need to give a documented reason for an issue.
Why was the Inside System sold/installed without FIRST identifying the problem(s) john bubber Structural Inspections 0 2/20/10 6:14 AM
Identifying and describing heating systems. inxil InterNACHI & RealMatcher Blogs 0 9/18/09 7:00 PM
Identifying laminated safety glass kshepard Interior Inspections 6 5/6/09 11:39 PM
Help identifying piping mmorgan Plumbing Inspections 3 8/2/06 8:40 PM
