sspradling is a non-member guest and is in no way affiliated with InterNACHI or its members.
Inspected a nice old victorian 3 story today. When I got on the 1-5 year old roof, I saw the lightning rods had been nicely cleaned up, but there was no grounding straps, cables, conductors, nothing. My question is: Would the owners be better off re grounding them, or would they be ok to just be a decorative bauble? I haven't seen that many lightning rod systems except in the country, and they have all been intact, all the way to an electrode in the ground. My gut feeling is that if the rods are up there, there should be a properly installed, complete system. Anyone know of any specs or references? Any first hand advise? Thanks in advance.
Stu |
i'm with you there. but i don't have a reverence either. if it's not grounded and is the highest point around, lightning hits it during a rain storm ( the rain giving it an electrical path to the earth.) are they helping or hurting?
This may help. . . 250.60 Use of Air Terminals. (Lightning Rods) Air terminal conductors and driven pipes, rods, or plate electrodes used for grounding air terminals shall not be used in lieu of the grounding electrodes required by 250.50 for grounding wiring systems and equipment. This provision shall not prohibit the required bonding together of grounding electrodes of different systems. FPN No. 1: See 250.106 for spacing from air terminals. See 800.40(D), 810.21(J), and 820.40(D) for bonding of electrodes. 800.40(D) Bonding of Electrodes. A bonding jumper not smaller than 6 AWG copper or equivalent shall be connected between the communications grounding electrode and power grounding electrode system at the building or structure served where separate electrodes are used. Bonding together of all separate electrodes shall be permitted. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net Last edited by jpope; 3/22/06 at 11:03 PM.. |
Jeff, thanks for the reference, I didn't know the code name was air terminals. Do you think an incomplete system for these things is cause for calling it out? Who do I defer this to, an electrician? I'd really like to get it right the first time. Again thanks for any help.
Stu |
Stuart,
When many of these older Victorians were built they were the tallest things around, and they commonly had Air terminals installed, these days you only tend to see them on Highrises, commercial structures and comunications towers. Whenever I have seen them I have defered them to a licensed electrician. I would certainly recommend that you note in your report that the Lightening rods were not connected at the time of inspection. Should they be re-connected frankly I don't know Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
I don't think I've ever seen a lightning rod, other than at the golf course IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
If I could figure out the new photo upload for my (previously not too large) images, I would be sharing. Maybe I'll figure it out some day..
Thanks for your help on this topic. Stu |
NFPA 780 Standard for the Installation of Lightning Protection Systems 2004 Edition
Chapter 1 Administration Chapter 2 Referenced Publications Chapter 3 Definitions Chapter 4 Protection for Ordinary Structures Chapter 5 Protection for Miscellaneous Structures and Special Occupancies Chapter 6 Protection for Heavy-Duty Stacks Chapter 7 Protection for Structures Containing Flammable Vapors, Flammable Gases, or Liquids That Can Give Off Flammable Vapors Chapter 8 Protection for Watercraft Annex A Explanatory Material Annex B Principles of Lightning Protection Annex C Explanation of Bonding Principles Annex D Inspection and Maintenance of Lightning Protection Systems Annex E Ground Measurement Techniques Annex F Protection for Trees Annex G Protection for Picnic Grounds, Playgrounds, Ball Parks, and Other Open Places Annex H Protection for Livestock in Fields Annex I Protection for Parked Aircraft Annex J(Reserved) Annex KProtection of Structures Housing Explosive Materials Annex L Lightning Risk Assessment Annex M Guide for Personal Safety from Lightning Annex N Informational References Formal Interpretation Index |
Well that certainly made it clear Joe
I know nothing about lightning rods (and may never have the need). Can you give some insight as to some of the basics? IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
http://www.nfpa.org/aboutthecodes/Ab...asp?DocNum=780
Preview this document. I posted this for review: Display the Table of Contents of this document. My intention was to identify the standard that may have some information to be used for a reference only. See Chapter 3. NFPA allows a review of all of their codes and that's where this is found, see www.nfpa.org codes and standards. Last edited by jtedesco1; 3/23/06 at 12:57 PM.. |
![]() The grounding electrode for a lightning protection system cannot be used for the building or structure grounding electrode system as required by 250.50. Figure 250–110 Author’s Comments: Paul W. Abernathy |
bkelly1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
In laymens terms. lol ... it should be bonded to something or lighting will find its own path. Ground or remove, that is my opionon. Have installed a dozen of these and they have to be grounded. We installed them on the many water and waste water plants I have wired, as well as all steeples on the churches I did. Back in the day.
They are not functional. No ground does it still draw lightening?
I think lightening does not always hit the hightest point, it may go for transformer/pole, tree, ground. Are you suppose to ground metal roofs? |
That is just my thoughts. There are companys now that are making plastic rods for this reason. My sister looked into them while building her house. The state inspector sais if they were copper, they would be grouded. Period. But maybe that is just him ?
| lightning rod question | wsiegel | Ancillary Inspection Services & Additional Topics | 6 | 11/21/07 10:47 PM |
| 2/12/2007- QOD - Electrical | pabernathy | Inspection Question of the Day | 62 | 2/20/07 2:41 PM |
| Lightning Protection Systems- Do You Check It? | pabernathy | Electrical Inspections | 20 | 12/29/06 9:38 PM |
| Electrical Inspection Training for Home Inspectors | jtedesco1 | Inspection Education & Training | 6 | 4/27/06 10:43 PM |
