Old 1/10/10, 5:40 PM
John Cahill John Cahill is offline
Default Need help on Texas terms
Texas terminology
Lots of questions for a sparky
Texas standards use terminology that might be slang. Also looking to define some requirements.
Texas standards state (6) electrical cabinets, gutters, meter cans, and panel boards that . . . etc.
I posted a question about the meter can terminology in the Texas forum. It seems “meter can” is slang and that meter base or enclosure is more accurate. Comment?
What is the difference between a electrical cabinet and panel board?
Are the clearances for a cabinet the same as a panel board?
What are the clearance and access requirements for gutters?
“Cut out box” is referred to. Internet states “In electric wiring, a metal enclosure that houses circuit breakers or fuses; is designed for surface mounting, with a swinging door or cover to provide easy access.” Is there one term that suffices for pane board, fuse box and cut out box?
Sop state “(15) the absence of anti-oxidants on aluminum conductor terminations; “. I thought anti oxidant was not required by NEC but considered preferable. Comment please. ?
SoP states “(7) cabinets, disconnects, cutout boxes, and panel boards that do not have dead fronts secured in place with proper fasteners;” What is a proper fastener?
SoP state “(13) a panel that is installed in a hazardous location, such as a clothes closet, a bathroom, where there are corrosive or easily ignitable materials, or where the panel is exposed to physical damage;” Is there any NEC reference to corrosion, easily ignitable materials or protection from physical damage regarding location?
Need a home inspection in Hawaii? Check out InterNACHI's listing of Hawaii certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/11/10, 8:25 AM
Jim Port Jim Port is offline
Unmoderated Guest
Default Re: Need help on Texas terms
Not from Texas, but will try to help.
[quote=jcahill;606626]Texas terminology
I posted a question about the meter can terminology in the Texas forum. It seems “meter can” is slang and that meter base or enclosure is more accurate. Comment? I would agree.
What is the difference between a electrical cabinet and panel board? See Article 100 for definitions.
Are the clearances for a cabinet the same as a panel board? I would think so.
What are the clearance and access requirements for gutters? NEC 110.26 covers work space requirements.
Sop state “(15) the absence of anti-oxidants on aluminum conductor terminations; “. I thought anti oxidant was not required by NEC but considered preferable. Comment please. ? No NEC requirement unless called for in the instructions.
SoP states “(7) cabinets, disconnects, cutout boxes, and panel boards that do not have dead fronts secured in place with proper fasteners;” What is a proper fastener? I would say the fasteners that came with the panel originally. Sheet metal screws have a pointed tip that could penetrate the insulation.
SoP state “(13) a panel that is installed in a hazardous location, such as a clothes closet, a bathroom, where there are corrosive or easily ignitable materials, or where the panel is exposed to physical damage;” Is there any NEC reference to corrosion, easily ignitable materials or protection from physical damage regarding location? Yes, Article 240 of the NEC would be the reference. 240.24 covers location and damage. 240.30 would cover damage also.[/quote]
Old 1/11/10, 9:16 AM
Thanks Jim, Will work through it
Cut out box is cutout box and is referenced in panel board definition. It seem similiar to cabinet defintion in NEC 100.
There are many terms for "enclosures". TREC uses them helter skelter. Creates a lot of questions.
Texas SoP is essentially inspecting to NEC code. That is a beeeech on older homes.
Texas Needs a Boot cbottger Thermal Imaging, Infrared Cameras & Energy Audits 1 12/26/08 1:52 PM
