Old 6/15/11, 3:07 AM
Julian J. Ortega's Avatar
Julian J. Ortega Julian J. Ortega is offline
Question Need some help with this... Extension cord for a Stackable unit?
I ran in to this today... An 220/240v electric extension plug for a stackable washer n dryer unit... It appeared to be substandard.. reason because it was just hanging off to the side? no form of secured mounting i tried doing a search for some kind of guidelines for these type of extionsions and found nothing...? I am open for advice and or comments...
need-some-help-extension-cord-stackable-unit-11410-brookshire-ave-407-downey-ca-90241-017.jpg   need-some-help-extension-cord-stackable-unit-11410-brookshire-ave-407-downey-ca-90241-016.jpg
Julian Ortega
AREA Property Inspections
jortega@ca.nachi.org
www.areainspections.com
Need a home inspection in North Carolina? Check out InterNACHI's listing of North Carolina certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 6/15/11, 7:10 AM
Robert Meier's Avatar
Default Re: Need some help with this... Extension cord for a Stackable unit?
Some would argue that the cord is a replacement for permanent wiring therefore not permitted. That appears to be an appliance cord and surface mount receptacle that someone made up to use as an extension cord.
Welcome to the Forum.
Old 6/15/11, 7:17 AM
mstankiewicz mstankiewicz is offline
In my opinion, I would be more concerned about the white plastic vent hose. These are a fire hazard. Especially when they are possibly pushed tight to wall as indicated in your picture. They are not real rigid, can crimp, then they will start blocking or filling with lint. The traditional metal type much safer.
For safety purposes always make sure your customers have smoke detectors and if they have any fuel burning appliances or attached garage, have a CO detector.
Cords are not designed to be fastened. Your picture looks like the proper manufacturer supplied cord designed for the dryer. I would be open if someone has something else to say about the cord question.
Good question Julian.
Old 6/15/11, 7:20 AM
Robert your right. Missed the 2nd picture. Duh!
Old 6/15/11, 7:32 AM
Is it just me or do most electricians install these receptacles upside down with the angle plug on the cord twisted over like in the photo?
Old 6/15/11, 7:43 AM
I do see it as pictured. Not a lot. Probably depends how many beers they had the night before. Ha haaa.
Old 6/15/11, 8:45 AM
Joseph Hagarty,  CMI's Avatar
No.
Extensions are temporary.
And the modification / alteration of the cord is improper
Cord on the appliance needs to be changed.
Joseph P. Hagarty
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 6/15/11, 8:52 AM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is online now
Since the unit is designed to be stacked. This is ok!
Manufactured plug allows room for options.
This allows them to expand on the basic cord length and the box is completely sealed.
Mark is right about the plastic vent being the fire safety issue.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 6/15/11, 8:58 AM
Improper extensions are permitted if the appliance is stacked
but
not if side by side?
interesting.....
Joseph P. Hagarty
Phone: 610-399-3675
Old 6/15/11, 9:07 AM
KEVIN WOOD's Avatar
What makes you think it is improper!
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 6/15/11, 9:12 AM
The electical box
installed on a Cut / Modified cord
laying on the floor
behind the dryer.....
Joseph P. Hagarty
Phone: 610-399-3675
Old 6/15/11, 9:16 AM
When I have found this...
it is usually a 3 prong wall receptacle
modified
to accept a 4 prong cord on the Dryer...
Home Owner Installation...
Joseph P. Hagarty
Phone: 610-399-3675
Old 6/15/11, 9:17 AM
For one thing the listing on that receptacle does not permit it to be used on the end of a cord laying on the floor. It's designed to be fastened in place. If a box is supported by a cord then it's an accepted standard to have a strain relief and a hub in the box.
314.23(1) Flexible Cord. A box shall be supported from a multiconductor cord or cable in an approved manner that protects the conductors against strain, such as a strain-relief connector threaded into a box with a hub.
Old 6/15/11, 9:36 AM
KEVIN WOOD's Avatar
I want to make it clear that I do not agree with it just hanging.
It needs to be fastened in a new location. I would still have it corrected just like the issue found on the back of Electrical stoves.
The unit must be an approved box or extension designed for its purpose and attached to the wall. In Canada the CSA tag must be on the cord and box.
This does look like a three wire design and therefore is not approved if it is.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 6/15/11, 12:21 PM
KEVIN WOOD's Avatar
AHJ says this is a problem when the existing plug was not installed at 42 inches. Only a licensed Electrical Contractor can make the changes.
According to the research no cord is acceptable to be altered from the unit without a proper permit.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
HELP! What do you call a 3 prong male plug with a cord. gromicko Electrical Inspections 5 1/9/09 12:33 AM
Extension Cord Wiring psmothers Electrical Inspections 1 6/4/06 9:11 PM
Joe F, update? jtedesco1 Electrical Inspections 54 4/10/06 10:35 AM
