Old 11/12/07, 7:56 PM
William M. Corbett's Avatar
William M. Corbett William M. Corbett is offline
Default Need some help. Pleeeeeeze
On one of my inspections today; there was an updated service panel. The 60 amp two pole GE breaker was 178 f. I didn't think to check the amps at the time (brain fart). It controlled the electric furnace that was running at the time. Oh, and the rest of the panel was between 80-85 f.
Any thoughts. Any comments would be very helpful.
Bill Corbett C.H.I.
Magic City Inspections LLC
InspectingtheUnexpected.com
Old 11/12/07, 9:05 PM
gbeaumont's Avatar
Default Re: Need some help. Pleeeeeeze
Hi Bill,
A 90 degree Delta T is way too much, in my opinion I would even consider that high if the breaker was GFCI or AFCI, call it out for further evaluation.
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 11/12/07, 9:26 PM
jwortham1 jwortham1 is offline
10 degrees difference. Not so bad.
90? WAYY too much. Lot's of resistance in there somewhere.
Like Gerry said, defer it to an electrician.
Jeffrey Wortham
ANS Inspections, Inc.
www.ansinspections.com
630.276.8440
638 Langford Drive
Bolingbrook, IL 60440
NACHI ID:04050181
Old 11/12/07, 9:36 PM
I did call it out, however for educational purposes,does anyone have thoughts on possible causes? Do you think it could just be a defective breaker? I have never had this problem with GE breakers. Square D occasionally, FPE all the time; never GE. My second guess was a problem with the furnace (wish I checked the amps).
Bill Corbett C.H.I.
Old 11/12/07, 9:50 PM
gbeaumont's Avatar
Hi Bill,
an amp load number would have been nice, but my "gut feel" is one of the following
  1. Defective breaker
  2. Poor connection between breaker and bus
  3. Loose conductor
MY best guess is #2
Regards
Gerry
(Mark B Adams)
NACHI02121106
Old 11/12/07, 9:59 PM
Jeffrey R. Pope's Avatar
Inadequately sized conductors will contribute as well. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 11/12/07, 10:06 PM
JP,
Thanks, but the conductors were #6
The panel had been recently updated (maybe 1 year old). I have sometimes seen discoloration to the contacts one side or both sides of a breaker (from a bad connection). I am thinking that it's a bad breaker.
Thanks to all.
Bill Corbett C.H.I.
Old 11/12/07, 11:16 PM
William J. Decker's Avatar
Originally Posted by gbeaumont
Hi Bill,
  3. Loose conductor
MY best guess is #2
Regards
Gerry
I agree with the funny looking man
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 11/12/07, 11:58 PM
At a certain point point it really doesn't matter what the problem is, a qualified person should look at it.
Old 11/13/07, 4:12 PM
Bob Elliott's Avatar
Just saw the pic and notice the red one is looking like the suspect.
Old 11/13/07, 4:53 PM
I don't think the amp load would be relevant.
I regularly used an IR thermometer to check up to 1500 amp breaker connections and rarely saw them more than 10-15 degrees over ambient.
(Granted, I never saw them at full load!)
Jeffrey Wortham
630.276.8440
638 Langford Drive
NACHI ID:04050181
