During the evening the lights in the family room went out. I checked and reset the breaker but to no avail. Upon testing the outlets I found that suddenly the hot and ground were reversed. Am I correct in thinking the breaker has gone bad on me?
| Need a home inspection in Georgia? Check out InterNACHI's listing of Georgia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I think you mean hot black and white neutral. I would think that it also is a bad light switch and this is a very common problem when they are old or have a loose connection.
THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
Sorry, maybe I should clarify further. The lights that went out in the family room are table lamps which are plugged into electrical outlets and controlled by wall mounted switches. When testing the electrical outlets I found that the hot and grounds were reversed. That is why I am thinking the breaker might have gone bad.
Hot and ground reverse means you have a short circuit messed up between the ground and hot. I would think it is at the plug and you shoud call a electrician ASAP.
Sounds like you may have a loose wire possibly grounding out. I would start by checking your outlets in that circuit to see if any are bad or the connections were loose.
Just some thought as well. I have found many times when testing gfci outlets, if the outlet doesn't reset properly my tester will show all outlets on that circuit as having reverse polairty. Once reset, it corrects the issue. It obviously had something to do with the connection. One can affect the rest. Dive on in Aubrey, you will find it. Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
Let us keep in mind that it not the voltage but amperage that kills you . 05 amps i believe, sounds like a short , remove the power , switch and outlets and use a ohm meter.
Wayne Wilson East TN Home Inspections LLC Knoxville, Oak Ridge, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-1490 http://site.myhomeinspection.net Last edited by wwilson3; 11/23/11 at 7:05 AM.. |
You may not de-energize this plug safely as Wayne is pointing out. Unless you can determine no power to the plug you should leave it to the electrician to analyze. If you start a fire or create a hazard you will not receive any insurance relief if someting goes wrong.
BTW some people react different to electrical shock and even at low amperage can not let go and in this instance you may become the path to ground. THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 Last edited by kwood; 11/23/11 at 7:41 AM.. |
Sean Please understand that I am not trying to jump on you in any way but this statement needs addressing even if you made it in pun. A 120 volt circuit protected with a 15 amp breaker is capable of delivering 1800 watts of electrical energy continually. To think that this is not enough to KILL is completely the wrong train of thought as it is more than enough to do damage or cause death Mike Whitt Contractor/Instructor |
Correct and even here in SSM On the ESA says when posible all power is to be removed from outlet before removal by electrician to make proper repairs.
I have to agree, this doesn’t sound like a breaker issue. When troubleshooting this type of electrical issue I would personally start at the point of the problem which sounds like the switch. Then move downstream testing and making corrections as needed. Also if this is beyond your skill level then refer to someone that is qualified. Always remember safety first.
You weren't clear. Was the breaker tripped? You stated you 'reset' the breaker "but to no avail" and the polarity was reversed. How did you check polarity, if "no avail". Perhaps the lamp socket went bad. Happens all the time. Not trying to bust your nuts, but getting the exact facts is important. No wonder some of youse catch crap from electricians and other tradesmen. Okay... that's more than one question, my bad. Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
Thanks for the input and guys. It was as I suspected, the CB had gone bad. A quick trip to Lowes and $4 later as is well with the world again.
I am still trying to figure out how if the breaker did not reset you were able to get the juice for testing outlets as reversed.
