Old 1/20/12, 6:55 PM
John M. Zirzow's Avatar
John M. Zirzow John M. Zirzow is offline
Default Need your opinion
Saw this on todays inspection, Had to do a double take. I have never seen one like this, OK ?
John Zirzow
Homestead Inspections llc
Eagle River, WI 54521
715-479-4151
Need a home inspection in Maryland? Check out InterNACHI's listing of Maryland certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/20/12, 7:03 PM
Joshua L. Frederick Joshua L. Frederick is offline
Default Re: Need your opinion
Double take at what? The box itself? If so, I see them all the time.
Old 1/20/12, 7:12 PM
That the electrical is so close to the plumbing, Should the outlet for the washing machine be GFCI protected. It just seems to me that if there was a backup in the drain or a leak in the hoses could be a problem.
John Zirzow
715-479-4151
Old 1/20/12, 7:37 PM
Jim Port Jim Port is offline
Unmoderated Guest
The NEC was recently changed to require GFI protection if the receptacle was within 6' of a laundry tub. That drain line would not trigger the need for GFI.
Old 1/20/12, 8:15 PM
Michael J. Parker Michael J. Parker is offline
It doesn't look like a very good idea
Michael J. Parker
The Neighborhood Home Inspector, LLC
Home inspections in Clinton, Essex and Franklin Counties in NY State
http://www.PlattsburghHomeInspector.com
www.TheNeighborhoodHomeInspector.com
Old 1/20/12, 8:52 PM
Unmoderated Guest
There is nothing in the NEC to prevent this install.
Old 1/20/12, 9:02 PM
Sean Fogarty's Avatar
Yeah you wonder who came up with that one. It doesn't look like a good idea deas it.
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
Old 1/20/12, 9:15 PM
Unmoderated Guest
Certainly no worse than if the receptacles were mounted in the drywall.
Old 1/21/12, 10:11 AM
Jeffrey R. Pope's Avatar
It is common for people to think the proximity of electrical and plumbing (as you have pictured) is, or should be prohibited, when in fact, it is not. Nor (in my opinion) should it be.
As Jim stated, GFCI protection would be required today, but the plumbing system is already (at least it should be) bonded to the electrical system.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 1/21/12, 10:15 AM
Robert Meier's Avatar
I see no problem with this installation.
Old 1/21/12, 11:02 AM
An HI An HI is offline
Please Note: An HI is a non-member guest and is in no way affiliated with InterNACHI or its members.
Mike Holmes would have a BIG problem with this. He scares the crap out of people when any water pipe is within 3-4 ft of the panel or especially if a pipe runs runs above the panel.
Old 1/21/12, 11:49 AM
Unmoderated Guest
The pipe above the panel may be a problem if it is in the dedicated space.
Also remember that he is in Canada where the CEC rules are different than under the NEC. It is also television. Heck the show the other day said they could not put light switches within 3' of a sink. Under the NEC they can be right outside the footprint of a tub or shower.
Old 1/21/12, 11:55 AM
And I always see Candice Olsen putting chandeliers over bathtubs and within 3' of the edge of a shower space. Is that legal in Canada?
Old 1/23/12, 7:50 AM
If there is not sink within 6' then it would not be a problem today either based on what it only shown here.
Paul W. Abernathy
Old 1/26/12, 10:15 PM
Pete Campbell's Avatar
Pete Campbell Pete Campbell is offline
I have seen that beast just once in Fort Pierce, FL and do not think it is UL listed.
Pete Campbell
pete4545@comcast.net
http://www.PortStLucieInspections.com
http://www.ChooseGI.com
http://ifwemissitwewillfixit.com
Inspecting Fort Pierce, St. Lucie Village, Lakewood Park, Vero Beach, Indian River Shores, Sebastian, Fellsmere, Fort Drum, Okeechobee, Jensen Beach, Stuart, Palm City, Hobe Sound and Indiantown, Florida.
SoPRFI Basis of opinion jcahill Texas/TPREIA Inspectors 5 6/1/10 9:16 PM
Attorney General's Opinion to TREC Request mboyett Texas/TPREIA Inspectors 11 12/5/09 11:44 PM
According to the latest opinion polls... jwilliams4 Miscellaneous Discussion for Inspectors 0 10/18/08 9:50 PM
Texas Atty. General Renders Opinion about Liability Insurance bthompson1 Legislation, Licensing & Legal Issues for Inspectors 45 12/20/07 11:57 PM
