Old 4/25/07, 3:20 PM
Scott Schultz Scott Schultz is offline
Please Note: Scott Schultz is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default netural not connected
I did an inspection today in which a 4 wire cable came into the box and 2 cables, the red and black were connected to a 2 pole breaker 50 amp breaker (A/C unit), the ground wire was connected to the bus bar and the white neutral was cut and bent back, not attached to a bus bar. Is this standard with 240v not to have the neutral connected?
Old 4/25/07, 3:30 PM
cbellefontaine's Avatar
cbellefontaine cbellefontaine is offline
Send a message via MSN to cbellefontaine
Default Re: netural not connected
It all depends on the appliance. If the circuit goes to a central AC unit, then it is ok. If the appliance is a combination 240 and 120 unit (Example, electric stove burners are 240 but the lights and computer is 120, then a neutral is required.) My guess is that it goes to the AC unit.
Where is surprise?
Sincerely,
Charles M. Bellefontaine
Bellman Group, Inc.
877-316-0600 Extension #802
Click Here to Join our Email Newsletter
Get Illinois Home Inspector Pre-License Education and
Continuing Education at www.bellmangroup.com
Low cost professional report writing with a contact
management system. www.myreportwriter.com
Old 4/25/07, 3:38 PM
thanks. surprise is in the northwest valley of metro phoenix.
Old 4/25/07, 9:51 PM
I remember when Surprise was in the middle of nowhere on the way to Vegas. The only reason you stopped there was if you drove a gas guzzler like my 442 and you couldn't make it quite into Phx, so you stopped in Surprise for some of their gas which must have had gold in it.
Old 4/25/07, 10:19 PM
David A. Andersen's Avatar
Three wire 240 VAC circuits do not require a neutral.
Old 4/26/07, 6:12 AM
Roy D. Cooke, Sr's Avatar
Examples ,welders ,some wood working equipment,most electric water heaters .
Roy Cooke
Hot & neutral wires connected abolt Electrical Inspections 1 11/26/07 11:56 PM
4 x 200 amp breakers connected mbarnett Electrical Inspections 7 9/30/07 10:55 PM
Romex connected to male plug... OK? ghawley Electrical Inspections 20 3/4/07 6:05 PM
Question re combustion air connected to vent jhawes Canadian Inspectors 11 12/4/06 9:24 PM
Romex wire connected to standard male plug. ghawley Electrical Inspections 2 3/2/06 1:35 PM
