Old 4/16/11, 11:14 PM
Justin Roberts's Avatar
Justin Roberts Justin Roberts is offline
Default Neutral and Ground
Can the neutral and the ground be on the same bus bar?
Yes I got the cut ground wire!
Justin Roberts
Roberts Property Inspections
PO Box 1972
Big Bear City, CA 92314
(909) 618-4697
BigBearHomeInspections.com
Need a home inspection in Minnesota? Check out InterNACHI's listing of Minnesota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/16/11, 11:23 PM
Christopher Currins's Avatar
Default Re: Neutral and Ground
Yes if located at, as some call, (Main) service panel, the panel with service disconnect.
No if located in (Sub) remote distribution panel.
But neutral and ground cannot terminate at same screw, like one in pic.
Christopher Currins
Certified, Licensed
Old 4/16/11, 11:25 PM
OK Thanks Chris
That was the "Main" and I did see that the "Sub" had to different bus bars.
Justin Roberts
PO Box 1972
(909) 618-4697
Old 4/16/11, 11:36 PM
Originally Posted by jroberts1 View Post
OK Thanks Chris
In the Sub the neutrals must be isolated from the panel and separate from the grounds.
Christopher Currins
Certified, Licensed
Old 4/16/11, 11:47 PM
James E. Braun, CMI's Avatar
Some panel manufactures' instructions may tell you different.
Braun Inspection Consultants
Serving Jefferson City, Columbia, Sedalia, Fulton and Lake of the Ozarks
Old 4/16/11, 11:49 PM
From what?
Christopher Currins
Certified, Licensed
Old 4/17/11, 12:04 AM
Dale Duffy's Avatar
You better get that CMI out of your name James, its a requirement to know what your talking about to use those initials----
Old 4/17/11, 7:37 AM
Linas Dapkus's Avatar
Linas Dapkus Linas Dapkus is offline
Sad but true
Old 4/17/11, 7:54 AM
Robert Meier's Avatar
Something seems strange to me. Typically a neutral bus is not bolted directly to the enclosure as this one appears to be. There is some separation from the enclosure, usually plastic behind it, so that it may be used in a subpanel without being bonded to the enclosure. Maybe I'm just being fooled by the photo.
Old 4/17/11, 8:00 AM
John Gromkoski's Avatar
John Gromkoski John Gromkoski is online now
If it's the main panel whats the difference?
774 Manor Road
Staten Island, NY 10314
718-514-3393
Old 4/17/11, 8:14 AM
Again I'm just speculating from the photo but if that is indeed only an equipment grounding bus, just bolted directly to the enclosure, then the neutral conductors cannot be terminated on it. The enclosure cannot be used to carry the neutral current back to the service neutral.
200.2 General.
(B) Continuity. The continuity of a grounded conductor shall not depend on a connection to a metallic enclosure, raceway, or cable armor.
Old 4/17/11, 8:36 AM
Roy D. Cooke, Sr's Avatar
Not In Canada Neutral and Ground are isolalated to their own buss.
And the neutral is only fastedend to the Primary panel ,not in any other panels
Old 4/17/11, 12:52 PM
Have you ever installed an electrical panel? Some electrical panels are even marked inside ground or neutral.
Inside panel: neutral & ground bus same thing? Drayman Eightysix Electrical Inspections 2 10/21/08 5:10 AM
What's this video worth? jtedesco1 Inspection Education & Training 5 4/18/08 9:24 AM
Ground wire in neutral bar, neutral to breaker, hot to ground? rmc3inspection Electrical Inspections 4 8/1/06 9:44 AM
