What is the potential problem when we attach 2 nuetrals and 2 grounds to one lug of the ground & nuetral bars at the main distribution panel?
408.41 in the code book states this issue but what problem can occur if the ground & nuetral is attached in the manor illistarted in the photo. |
rbrady is a non-member guest and is in no way affiliated with InterNACHI or its members.
The main risk is initiating a prolonged discussion on electrical codes which will degrade into a major pi$$ing match and bruised egos.
Besides that there is a remote risk of damage to electrical equipement if someone disconnects a neutral wire which is part of a multi-branch circuit without turning off the main breaker first. |
No ego's required. tom |
If I ask enough times maybe it will finally sink in. Thanks for your responses. Not trying to piss anyone of just trying to educate myself. |
Manufacturer comes and removes the panel board,for misuse... same as if you remove the label from the mattress.
Let me tell you about some of the electrical experts on this site.
We work for a highly funded yet unofficial government agency. Our mission is to monitor doubled up neutrals on the NACHI site. From now on, you will notice that we have no identifying marks of any kind, as we are no longer part of the system... We are the Men Behind Keyboards. "Pay no attention to the man behind the curtain". http://www.youtube.com/watch?v=YWyCCJ6B2WE |
| THE "GROUNDING "TRUTH- Article To Read | pabernathy | Electrical Inspections | 1 | 1/1/07 2:14 PM |
| Bare wire on old dryer or stove circuit: neutral or ground? | fbartlo | Electrical Inspections | 9 | 8/28/06 2:08 AM |
| Ground wire in neutral bar, neutral to breaker, hot to ground? | rmc3inspection | Electrical Inspections | 4 | 8/1/06 10:44 AM |
