I saw this today. Most times I see neutral and ground on the same bar but different lugs. This panel has about 9 on the same lug. Is it acceptable?
Lou P. |
this may help you (I believe someone posted this a while back)
************************************** Shawn Rowe, CMI HomeFirst Inspection Services, LLC - InfraRed Specialist (Level 1 & Building Science certified) - Code Certified Residential Building Inspector - Certified Master Inspector -- Serving NE Florida, St. Johns, Duval, Flagler, Putnam counties -- |
Is it the entrance panel, or a distribution panel? Distribution panel must be separate bus bars; one neutral grounded conductor to one terminal screw; grounding can be doubled.
Lugs, Bugs, Bars, Oh My.
I'm getting the sense there is a miss communication going on here since there is a terminology mix up. I believe the OP is asking if Equipment Grounding Conductors "Grounds" and Grounded Conductors "Neutrals" can be on the same bar? Even though they are under different terminal screws (what I think the OP is calling lugs). Under certain conditions this is ok. However, you compound two questions into one paragraph, and mention you see one with 9 'somethings' under a 'lug'. huh? Rather than explain what you meant, a photo would be nice. tom |
Ah, there is the photo I was looking for...
tom |
| Bare wire on old dryer or stove circuit: neutral or ground? | fbartlo | Electrical Inspections | 9 | 8/28/06 1:08 AM |
| Ground wire in neutral bar, neutral to breaker, hot to ground? | rmc3inspection | Electrical Inspections | 4 | 8/1/06 9:44 AM |
