Old 1/10/12, 9:59 AM
JAMES DAVIS JAMES DAVIS is offline
Please Note: JAMES DAVIS is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default NEUTRAL and ground together in sub panel
When is it ok to put ground and neutrel on same bus bar.
Need a home inspection in Delaware? Check out InterNACHI's listing of Delaware certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/10/12, 12:32 PM
Robert Meier's Avatar
Default Re: NEUTRAL and ground together in sub panel
If the panel was located at a separate structure and they were under the 2005 (I believe) or earlier versions of the NEC.
Old 1/10/12, 12:37 PM
Jeffrey R. Pope's Avatar
... and there are no other metallic paths (connections) between the structures, i.e. metal conduit, metal piping, cables/low voltage wiring, fencing, etc.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 1/10/12, 12:46 PM
Yes that's true. I was focusing on the requirement applying to separate structures. If the structures are not separate then I don't think that it was ever permitted.
Old 1/10/12, 1:12 PM
Joe Funderburk, CMI's Avatar
A difficult thing to determine during a home inspection, so refer it to a sparky.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 1/10/12, 1:17 PM
That has always been my position as an inspector.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 1/10/12, 4:42 PM
Joseph M. Whitt Joseph M. Whitt is offline
In any enclosure that contains the service disconnect is the only place where this is permitted except in earlier editions of the NEC where a remote building is supplied by a three wire feeder and another grounding electrode system is established.
Mike Whitt
Contractor/Instructor
Old 1/15/12, 12:22 PM
Thank you , Mr Whitt. I have one more question, this remote well I am hooking up is a 3 wire connection and I was wondering if I could use a single pole 120/230 breaker.
Old 1/15/12, 12:42 PM
Is this a home project or is it related to an inspection?
Old 1/15/12, 1:04 PM
It is an inspection,thank you.
Old 1/15/12, 6:06 PM
Jim Port Jim Port is offline
Unmoderated Guest
A single pole breaker will only supply 120, not 240.
A tandem will allow two circuits of 120.
Old 1/15/12, 6:16 PM
ROBERT V. YOUNG's Avatar
ROBERT V. YOUNG ROBERT V. YOUNG is offline
Good to know and note taken.
My weakest subject for now.
montrealbuildinginspectionservice.com
montreal-home-inspection-services.com
home-inspections-montreal.com
homeinspectionsservicesmontreal.com
ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC.
Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI)
OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816
Old 1/16/12, 12:10 PM
Why do they sell a single pole 120/230 breaker if it cant do what it says:
Old 1/16/12, 2:49 PM
Not sure I understand, where are you finding a 120/230 volt circuit breaker? If anything a slash rated breaker would be 120/240 not 230.
Old 1/16/12, 2:52 PM
Christopher Currins's Avatar
James you said this
What I am hooking up is a 3 wire connection and I was wondering if I could use a single pole 120/230 breaker.
Ask your self, where would I connect 3 wires at a panel with a single pole breaker?
http://electrical.about.com/od/panel...fanduseage.htm
Christopher Currins
Certified, Licensed
Electric Panel dmozzillo Electrical Inspections 26 1/26/09 1:18 PM
What's this video worth? jtedesco1 Inspection Education & Training 5 4/18/08 9:24 AM
