Old 11/20/06, 10:15 PM
Tab M. Wilcox Tab M. Wilcox is offline
Please Note: Tab M. Wilcox is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Neutral Magic
Professional job !!
Old 11/20/06, 10:16 PM
Brian E. Kelly's Avatar
Default Re: Neutral Magic
WOW
Old 11/21/06, 12:27 AM
Darrell B. Hadler's Avatar
Darrell B. Hadler Darrell B. Hadler is offline
Geezzz...I'm going to have to add a few more descriptive defects to my reports.....triple taps.....quadruple taps......quintuplit taps
Maybe to keep it simple....Multi - taps.
Darrell Hadler CMI
Five Star Home Inspections
Medicine Hat, AB. Canada
NACHI# 04111082 Cell phone# (403)502-3593
Inspected once . . . inspected right!
Old 11/21/06, 1:15 AM
tdietrich1's Avatar
Even after all that, they still managed to get more than one neutral under a screw.
Geez....
Old 11/21/06, 6:41 AM
Unmoderated Guest
That is one of the scarriest things I have ever seen! ESPECIALLY from a pro.
Again, not only did they manage to funnel potentially hundreds of amps worth of current through three #12s, they are all in the same hole.
Proof that few inspectors (electrical that is) remove panel covers.
Old 11/21/06, 9:20 AM
Simply a shame to the profession.......Would LOVE to speak with the "PRO" who did this and explain a few things.
Never seems to amaze me what people will do.
Paul W. Abernathy
Old 11/21/06, 11:00 AM
Roy D. Cooke, Sr's Avatar
I sure hope this was not done by an electrician .
This is a disgrace
Roy Cooke
Old 11/21/06, 11:23 AM
This condition was found in a 1 year old home. The home is located in a small municipality with a weak AHJ. I believe this work was performed by a licensed electrical contractor. Tab
Old 11/21/06, 9:55 PM
tdietrich1's Avatar
Weak or strong AHJ is regardless, common sense should prevail. I hope the home owner plans on suing the electrician. Or at least exposing his work to the media.
Old 11/23/06, 9:05 PM
We had a similar question over at Bob Badger's house except the single wire was 250.66 size (or alternately computed for 250.122 based on worst case phase loading). I don't think anyone really came up with something that said it was wrong specifically in the code. Obviously using a #12 would not meet the 250.122 test (adding up all the overcurrent devices)
Old 11/23/06, 9:11 PM
Greg code # do not mean much to most home inspectors including me . Thanks Roy Cooke
Old 11/23/06, 10:04 PM
250.66 is the size of the ground electrode conductor, based on the service conductor size and 250.122 is the size of the equipment ground conductor, based on the breaker size.
Old 11/23/06, 10:48 PM
Doug Edwards's Avatar
This was the ground wire on an electric furnace yesterday.
THE "GROUNDING "TRUTH- Article To Read pabernathy Electrical Inspections 1 1/1/07 1:14 PM
Metal Rigid or PVC Rigid what is code bpotts Electrical Inspections 5 12/4/06 2:40 PM
Ground wire in neutral bar, neutral to breaker, hot to ground? rmc3inspection Electrical Inspections 4 8/1/06 9:44 AM
Proposed Definition of Neutral Conductor and Point jtedesco1 Electrical Inspections 1 4/22/06 10:19 AM
