This morning I looked at an electric Nortron furnace. The white nuetral wire from the main panel was not connected to the nuetral bus bar in the main panel , nor was it connected to a terminal (left uncapped) in the furnace.
Does it not have to be connected to "complete" the circuit"? |
If it is 240V it does not use the neutral wire. It should be grounded though. Either through the use of a green wire back to the panel or, if EMT is used, the EMT itself.
Jeff Jeff Wicklander Corwick Home Services Join my business on Facebook
| Main panel..... grounding wire...need advice | dnasser | Electrical Inspections | 4 | 10/4/10 12:37 PM |
| Main panel..... ground wire question | dnasser | Electrical Inspections | 4 | 7/11/10 1:15 AM |
| Can a main panel be a sub if?? | sfogarty | Electrical Inspections | 8 | 4/23/10 4:57 AM |
| Panel Questions - main, mid, sub | lfoster | Electrical Inspections | 6 | 11/11/08 9:42 PM |
