Newer SD 200 amp main service panel. Most of the grounded & grounding conductors were installed appropriately on the bus bars. However there were two isolated (bonded to panel) bus bars on both sides, with a few grounded & grounding conductors installed there. Now, I know the grounds are o.k. here, but what about the neutral wires and/or grounded conductors? Do the neutral wires need to be installed at the main neutral bus bar(s)?
Thanks in advance. |
| Need a home inspection in Maryland? Check out InterNACHI's listing of Maryland certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Those neutrals conductors are not permitted on the EGC bus even in a service panel as shown in that photo. I see a main breaker, is this the service disconnect?
Thanks Robert, just wanted to confirm.
The problem is that you now have return current on the metallic enclosure where you should not. RM has posted the code prohibition below.
Please help me out. Isn't that a bonding screw at the bottom of the grounded conductor bus bar?
That is a lug for a larger conductor. The bond screw on that Square D panel is out of the pic. It is a green domed head screw near the main breaker.
As it is now the neutral current will flow across the enclosure to the bond screw and then through the neutral buss and then out to the transformer. |
Thanks for the help.
Am I correct in my statement Jim. montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 |
The domed screw is just for the Square D. The correct location is shown on the panel label.
IIRC Cutler-Hammer Classic uses a bond strap into the buss. |
| Main Disconnect missing verbage & cut main wire | rwashington | Electrical Inspections | 19 | 1/16/11 2:07 PM |
| Main panel without...Main Disconnect, need help | dnasser | Electrical Inspections | 8 | 10/4/10 11:34 PM |
| Main Panel vs Sub-Panel and main disconnect? | rbassett | Electrical Inspections | 11 | 10/24/09 6:16 PM |
