There is a main disconnect panel at the exterior of the house and recent modifications (additions) to the house have occurred. The need for additional electrical demands were needed.
Is this a correct modification? Never have seen one of these (appears to be a junction device of some type) that is present. Thanks in advance. ![]() ![]()
Comprehensive Building Consultants Naples Home Inspection, Naples Mold Inspection, Naples Radon Inspection, Bonita Springs Home Inspection, Bonita Springs Mold Inspection, Bonita Springs Radon Inspection. Donate here: or send checks to the Fl Home and Insurance Inspector Chapter 1103 W Hibiscus Blvd Ste 311 Melbourne, Fl 32901
| Need a home inspection in North Dakota? Check out InterNACHI's listing of North Dakota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
it looks from here that these places occurring before the main panel circuit breaker so the main circuit breaker on the exterior of the house exceeds the capacity of the small wires attached before the subpanel.
The devices are probably fine, but their location is the problem. The added circuits are "over fused". "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
It is hard to tell if that is a proper use of the tap rules from the pics.
Those are pre-insulated wire connectors. Think expensive wire nuts. |
The bottom lines are the feed lines from the meter. The upper lines are the ones that distribute power to the house.
Notice the double taps on the left side neutrals. Does this help? The wire connectors have one wire and then TWO wires. Is that permissable?
No that is not allowed.
They should have made one of those knuckles. |
If so, these are a substitute for a split bolt without all the taping. |
One conductor per hole.
Yes that is what I meant but the neutral in the latter picture is a double tap.
Yes as Jim said one conductor per hole unless the connector is listed for more than one conductor, and the neutral is double tapped as Bob said. How are these conductors terminated on the other end?
