Inspected a house yesterday - the kitchen has 2 GFCI outlets - one of the won't reset without resetting the other outlet - can they be tied together?
| Need a home inspection in New Jersey? Check out InterNACHI's listing of New Jersey certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
You can install multiple GFIs on the same circuit, but if wired properly there is no need. Downstream receptacles can be regual duplexes if wired from the LOAD terminals on the upstream GFI. You could also just use the LINE terminals and make each receptacle a GFI. That way if it trips it is near the point of use and you do not need to look elsewhere.
Did the kitchen have another 20 amp small appliance branch circuit? |
The other strange thing is when I tested the upstairs bathrooms - they tripped but I couldn't find a reset anywhere in the house or panel - thoughts?
I have often found them to be connected to an exterior outlet.
Greg Bell Titusville, Fl 02111507 Serving Central Florida
Really - So if you trip one , you have to go outside to reset - that shouldn't be in code - saftey issues.
Greg - the same house has a hipped roof and the truss run parallel to the wall - the sheathing is not flush with the truss - thoughts?
Some GFCIs are in the garage for the bathroom outlets etc.. Just so they are present
Jim my house is 1997 and when I built in the early 2000s they were shared. Down here I belive it was enforced mid 2000s ?
problem was that folks would wake up in the morning after heavy rains, wind or fog to find the circuit tripped by moisture at an exterior receptacle and no power at bath receptacles .
That just happened at my house the GFCI is in the garage |
Where was the moisture from......... or some other type of nuisance trip?
My wife has some lights on the Lanai with a timer. We had a blowing rain hit the outlet 4' under the OVH.
Yep.
Andrew Nazir is a non-member guest and is in no way affiliated with InterNACHI or its members.
quite right, as its safer too to put all the connectors outside of home.
| Options in selecting materials for basement construction | wdevries | Canadian Inspectors | 2 | 8/4/08 1:30 PM |
| Selected Electrical Incidents and Occurrences - First Quarter | pabernathy | Electrical Inspections | 0 | 12/2/07 1:43 PM |
| IAC2 In new residential construction | mcyr | IAC2 Indoor Air Forum | 0 | 10/9/07 6:45 PM |
