Old 11/28/06, 9:38 AM
thejnicki's Avatar
thejnicki thejnicki is offline
Default New Disconnect
This pic was taking inside a new AC disconnect.. Tkae a look at the wire on the right, notice the corrosion and discoloration.. How would you write up this condition or would you not write it up?
Old 11/28/06, 10:14 AM
ccbrands1 ccbrands1 is offline
Please Note: ccbrands1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: New Disconnect
I always write up corroded conductors.
something like:
"copper conductor is corroded. recommend a licensed electrical professional find source of corrosion and repair/replace"
simple...write it up for what it is, recommend repair, and move on.
Old 11/28/06, 10:37 AM
From the picture it looks like the insulation is melted too. I would certainly write up for a sparky to correct.
Abraham Lincoln
Old 11/28/06, 11:00 AM
thejnicki's Avatar
Thanks, I appreciate the input.. You guys always solidify things for me..
Old 11/28/06, 11:20 AM
bkelly1's Avatar
bkelly1 bkelly1 is offline
Please Note: bkelly1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Screw looks loose and has caused heat build up.
Old 11/28/06, 11:31 AM
Jeffrey R. Pope's Avatar
That would be my guess - a loose connection. This should absolutely be called out.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 11/28/06, 11:46 AM
Fubared
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 11/28/06, 7:00 PM
Not only would absolutely write this up, but I would flag it as a fire hazard that should be immediately addressed.
Exterior Service Disconnect Clearances? rcramer Electrical Inspections 18 7/28/07 1:12 PM
50 amp disconnect for 1600sf condo kmccullough Electrical Inspections 5 4/10/07 8:49 PM
A/C Disconnect question rslocum Inspecting HVAC Systems 15 9/21/06 12:16 AM
100 Amp Meter, 200 Amp Disconnect jweinberg Electrical Inspections 8 8/15/06 12:32 PM
HVAC Disconnect kgore Inspecting HVAC Systems 11 7/11/06 6:58 PM
