Old 3/22/08, 7:56 PM
Randy D. Stufflebeem's Avatar
Randy D. Stufflebeem Randy D. Stufflebeem is offline
Default New one on me
I am kinda lost on this one guys and I am not sure if you can figure it out from such a poor photo but here it goes. It appears to me the fused panel on the left is the main. It has incoming #3 Awg Copper conductors. But it also appears the load center is rated at 60 AMP (It says A. 60 240V on the front). The sub-panel is a GE load center 125 AMP max Breaker set up. I have reported it as 60 AMP and now I am not sure since I rarely see a set up like this let known fused as oppose to breakers. I hope you can somehow blow up the photo to get a closer look. There is also double tapping and such and all was written up. Okay fellas beat this one up and let me know if I am correct to say 60 AMP. Realtors get funny when it comes to reporting 60 AMP service.
Thanks in advance and Happy Easter!
Old 3/22/08, 8:03 PM
Michael Larson's Avatar
Default Re: New one on me
Randy, what feeds the newer distrubution panel?
Any better pics?
Michael Larson
Hudson, WI
[/I]
Old 3/22/08, 8:05 PM
Any better pics?
Michael,
I apologize I have no better pics but the incoming to the newer panel is #6 AWG Copper. Hope this helps!
Old 3/22/08, 8:09 PM
Originally Posted by rstufflebeem
Michael,
Was it fed by the range "pullout" or doubled up with the incoming #3?
Michael Larson
Hudson, WI
[/I]
Old 3/22/08, 8:13 PM
I will look up the report and get back to you. Off to Easter Mass! Thanks for your help so far.
Randy
PS: Been a brutal Electrical week for me!
Roy D. Cooke, Sr's Avatar
Weakest link in the chain It says 60 amp then thats what it is.
...Cookie
Old 3/22/08, 8:25 PM
Kids are not quite ready to go! It is fed by the "pull out" on the right side. I am weak with fused anything so the more you can give me the less I have to bug you all with it later Gotta go Catholic Easter mass lasts like a million years. I will check back later!
Thanks
PS: Cookie, agreed!
Old 3/22/08, 8:27 PM
I am betting this is 100a service with a split bus panel using the right pullout to feed the GE breaker panel at 60a.
Unmoderated Guest
That's a 100A service. The "sub" is off the 50 or 60 amp "range" fuses.
One pullout kills the fuses, the other kills the new breaker panel.
Old 3/22/08, 8:32 PM
Mike I didn't see any double lugging on the 60a pullout or the main lugs (zooming the picture)
My guess is the range got moved to the lower left 2 pole breaker.
Old 3/22/08, 8:41 PM
rbrady's Avatar
rbrady rbrady is offline
Please Note: rbrady is a non-member guest and is in no way affiliated with InterNACHI or its members.
From my experience, those types of panels typically have 60 - 100 amp cartridge fuses for the main fuse. I never know for sure because I'm not about to pull them out to check. You can get a good idea by looking for the label on the panel. The second panel is fed through the second set of cartridge fuses which would be rated at 40 - 60 amps.
BTW - to enlarge the photo view try CTRL+. (hold the ctrl key while pressing =/+ key) It works on my Windows XP with explorer 7.
Old 3/22/08, 8:49 PM
That's the way I saw it too. Tough to tell from the small pics.
Should be a 60 Amp Service then agree?
Michael Larson
Hudson, WI
[/I]
Old 3/22/08, 9:08 PM
rromoser's Avatar
rromoser rromoser is offline
This panel appears to be a 60 amp service. Cartridge fuses rated for 100 amps typically have 1/2 inch copper blades at each end. This makes them longer than 60 amp cartridge fuses. Usually a 100 amp panel with a single main pull-out is located at the top of the panel all by itself. Not side by side with another pull-out.
BTW The main is the left pull-out.
Old 3/22/08, 9:17 PM
No this looks like 100amp. There is no "main" hence no 100a fuses. It is a split bus panel. One pullout goes to the plug fuse array in the bottom and the other is now feeding the breaker panel. The rails behind the pullouts are hot all the time.
Old 3/22/08, 9:21 PM
Unmoderated Guest
And the "Range" main is on the right.
