Old 2/6/12, 2:07 PM
James L. Keilson's Avatar
James L. Keilson James L. Keilson is offline
Send a message via ICQ to jkeilson
Default Nice Drop Ceiling Findings
It never amazes me, but what are some people thinking This was in a recently finished basement. I found all this just before the Polybutylene was discovered.
Jim
nice-drop-ceiling-findings-100_1639.jpg   nice-drop-ceiling-findings-100_1637.jpg   nice-drop-ceiling-findings-100_1638.jpg
Maryland Home Inspection Services Inc.
www.MarylandHomeInspectionServices.com
State of Maryland License# 31141
Virginia License#3380 000468
National Association Of Certified Home Inspectors ID: NACHI10101807
International Association of Certified Indoor Air Consultants (IAC2). Certification # IAC2-02-0919
Maryland Home Inspectors In Gaithersburg, Rockville, Germantown, Bethesda, Potomac, Also All of Northern Virginia and Washington, D.C.
Need a home inspection in Georgia? Check out InterNACHI's listing of Georgia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/6/12, 2:14 PM
Robert Meier's Avatar
Default Re: Nice Drop Ceiling Findings
I would expect to see this on a DIY basement project. Was this done by a homeowner or a contractor?
Old 2/6/12, 2:57 PM
Bob Elliott's Avatar
Good catch James.
Believe it or not some Inspectors never look above drop ceilings.
Old 2/6/12, 3:03 PM
David P. OKeefe's Avatar
David P. OKeefe David P. OKeefe is offline
Originally Posted by belliott View Post
Good catch James.
Hay, it's not required and I can shave ten minutes off my inspections. Makes the agents happy.
David
InterNACHI #08051301
NYS Lic. #16000038229
NYS DEC Cert # T4865884
518-505-8305
HouseAbout Home Inspections
HouseAbout on Facebook
NY Capital Region Chapter InterNACHI
Old 2/6/12, 3:12 PM
Plus you can scream SOP (and not required).
Find this kinda stuff all the time.
Just gotta learn which ones to remove to spot check.
Old 2/6/12, 3:57 PM
Mark Raumikaitis Mark Raumikaitis is online now
I see this a lot; I am 6'6" tall so those drop ceiling panels are right there above my head; no step stool needed. I always spot check a few and always make sure I see at least one of the recessed light fixtures. The other spot I look is the perimeter frame adjacent to an exterior deck...quite often find water infiltration and/or rot due to poor or missing flashing. These are all cant miss locations during my inspection.
Mark Raumikaitis, CMI, NH Lic #133
HomeCheck Professional Home Inspections LLC
Derry, NH
603-432-3211
Inspecting New Hampshire and Southern Maine
http://homecheckhomeinspections.com/
"Always think long term, do not be influenced by short term thinking or rewards."
Old 2/6/12, 4:13 PM
Good tip ,and you want to see if they are using plug in light fixtures to open junction boxes all the time as it seems to be a common issue.
Old 2/6/12, 7:29 PM
Thanks Bob, I do try to spot check a few and pop my head in there to see whats hidden. This was supposed to be a real contractor job, but after a few mins of research I uncovered no permit pulled for the basement. This was just the tip of the iceberg in this house. There was upside down insulation, polybutylene piping, romex OUTSIDE feeding a hot tub, basement bath fan exhaust into laundry room ceiling...yada yada/ The report took forever as almost everything I looked at had some type of deficiency But in the end I was happy as it was just a 2300 sq ft for $650.00 + another $115.00 for Radon
Mark you got me beat, I am only 6'1" so sometimes I need a step..haha
Jim
Old 2/6/12, 7:34 PM
I try to be The best I can be and for the most part am not concerned at all about the agents The only thing most agents are needed for ( at least for me) is to open the door.
Jim
Old 2/7/12, 9:31 AM
David C. Macy's Avatar
David C. Macy David C. Macy is online now
I check above drop panels all the time and I can pick a panel and typically find an issue above be it electrical, heating, smoke detectors, plumbing.
I can spot a homeowner job as soon as I get into the finished basement.
If I see drop panels in kitchens and baths and it is typically a cover up.
I had one the other day that the bath was leaking, major damage to ceiling above drop and most likely asbestos materials. All agent cared about was me placing tiles back as he had several showings later in the day.
If as an inspector you are not moving a few panels then I feel you are not providing a proper inspection and service.
SOP is the minimum standards. Put that in your pipe and smoke it!!
I also provide a disclaimer that only a few panels are removed at radon locations and defects still may exist that I could not see. I find rodent infestation above panels as well.
Performing Home Inspections in Cleveland, Strongsville, Brecksville, Broadview Heights, North Royalton, Parma and surrounding areas.
Old 2/7/12, 10:10 AM
Dave I agree with you 100%
Jim
Plastic ceiling fan box? jfunderburk Electrical Inspections 21 11/3/10 1:58 PM
And behind this drop ceiling panel is... dmacy Electrical Inspections 11 3/28/10 9:34 PM
Vaulted Ceiling Insulation rcooke Canadian Inspectors 4 1/22/07 12:24 PM
Ceiling discoloration from joists? dtaylor General Inspection Discussion 4 8/3/06 12:27 AM
