Anyone writing them up for being absent, even if not required by the AHJ?
Think about this: Currently, your AHJ does not enforce the requirement for AFCIs in living areas. The new house you just inspected didn't have them and you didn't mention their absence in your report because "it's not required". Pretend that the national code for AFCIs in living areas get's adopted next year by your AHJ. Three or ten years from now, the same home gets inspected by another home inspector. He writes up AFCIs for being absent in living areas, knowing that national codes called for them in 2008 and he doesn't keep track of when each AHJ decided to finally enforce it. The homeowner will then have to buy the AFCIs at about $40 each and install them to sell the house to the next buyer. If there's a shared neutral on the circuit, the retrofit could be very expensive in electrician costs. You, the home inspector they used to love, now looks bad for not having written them up when the house was new. This is how I write up GFCIs: If they aren't present at all counter-top outlets in the kitchen for a home built after 1996, I write it up as a significant issue and recommend "repair" (not an upgrade). Period. It is likely, however, that the AHJ didn't require them beginning in 1996. Too bad. I write their absence anyway. I'm just thinking that we need to write up the absence of AFCIs NOW on new construction regardless. Put in a statement that it may not yet be adopted, but we recommend it. I did a home today that had the child-proof outlets, but not AFCIs in living areas. The outlets were there because of a company policy (they operate in different states/counties and just do it everywhere whether required by the AHJ or not). Thoughts? “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
| Need a home inspection in Rhode Island? Check out InterNACHI's listing of Rhode Island certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Do you write up the absence of a sprinkler system?
James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 Inspecting in Aurora, Branson, Carthage, Granby, Joplin, Kimberling City, Monett, Mount Vernon, Neosho, Nixa, Purdy, Reed Spring, Republic, Springfield and surrounding areas. |
The 2009 IRC calls for them in new structures....same principle that you are using regarding AFCIs.
I thought you meant an irrigation system. Sorry.
I currently recommend AFCI in all bedrooms .
Not sure I would call that writing it up as a term,because it sounds like I am a code authority. What a guy in the star Trek future calls out or writes up is not my concern. |
First off, the gfci comment.... Why use a code date to start recommending gfci's in the summary for areas that have been determined to be higher risk areas? You have told me before that you did not use code dates if you felt it was a safety issue. I recommend gfci protection for all normal/typical gfci areas even on a 1930 house and put it in the summary. One of the nice things about having a report that contains a "summary" (as we are required to call it in NC) is the ability to have the report body section for entering additional information and upgrades. Some of the upgrades I report now may become a summary item in the future as more tangible information becomes available. We have limited information about any house fires actually prevented by AFCI's so they are just one of those nice new advances that are slowly making its way into construction. If you feel they are very important then you should report it in the summary but you should make it known that the absence of these is typical in many areas. Some areas don't even require them on bedroom circuits yet. Don't forget that a city or county can file for an exemption to leave out parts of a state code if they want to. Don't forget, lack of a GFCI leaves no backup system, someone can die pretty easily. Lack of an AFCI AND the existence of an issue that WILL combust into a fire still leaves the smoke detectors as a backup as well as the likely chance the regular type breaker will just trip from an arc. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
I still do not understand the idea of writing up AFCIs for new construction and not sprinkler systems.
It doesn't make sense. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 Inspecting in Aurora, Branson, Carthage, Granby, Joplin, Kimberling City, Monett, Mount Vernon, Neosho, Nixa, Purdy, Reed Spring, Republic, Springfield and surrounding areas. |
This thread is another good example of why home inspections and code inspections are done by two different job descriptions.
For most inspectors, I think, if they start seeing something a lot on new construction and then do not see it on one then they will write it up. Joe and I work in two states, 6-8 counties and countless townships and cities so we see a wide variety of new and old construction. For the average house, a knowledgeble code inspector could find 10k-15k worth of code issues. The problem is that he would be technically wrong on some since the AHJ had opted out of enforcing many of them. The bottom line is, if you think a house needs a sprinkler system then by all means call it out and say the occupant could die with out it. Your opinion is never wrong when recommending the addition of safety systems. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
I've been a code inspector. A code inspector has no liability, for he is indemnified by the city...as long as he actually does the inspection. He can never be wrong and he spends, usually, less than thirty minutes on site. Code is not an indicator of safety or quality. Code is nothing more than a minimum basic standard. A house that simply meets the minimum basic standard is assured of being "safe" as much as a newly licensed inspector (who has also simply met a minimum basic standard) is assured of doing a "perfect" inspection. Codes are a starting point. Less than code is illegal. That is all we should know or care about them, IMO. If you are NOT going to go all the way and recommend every safety feature in the latest code...don't refer to any. Simply use your best judgment, make your recommendations, and move on to the next house. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 Inspecting in Aurora, Branson, Carthage, Granby, Joplin, Kimberling City, Monett, Mount Vernon, Neosho, Nixa, Purdy, Reed Spring, Republic, Springfield and surrounding areas. |
For an inspector that wants to inspect to the latest code, which one do they use? Chinese code? Russian code? IRC? yes? Why the IRC if the AHJ has chosen to not use all of the IRC? You are making up your own code when you do not know what the local AHJ has chosen to enforce and yes they DO NOT try to enforce all of the code and they even miss some other parts that they intended to enforce. Write up items based on your knowledge based on codes etc not the code you wished was enforced. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 Last edited by bking; 2/1/10 at 11:55 PM.. |
You are no safer in basing your recommendations on the code being enforced than you are any other code. I can tell you from experience that codes, where enforced, are not enforced consistently. Exceptions are regularly granted. You have no way of knowing during an inspection if the builder was granted permission to deviate from a particular requirement or not. Go with what you know to be the best building practice and recommend accordingly. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 Inspecting in Aurora, Branson, Carthage, Granby, Joplin, Kimberling City, Monett, Mount Vernon, Neosho, Nixa, Purdy, Reed Spring, Republic, Springfield and surrounding areas. |
I saw a long run on a dryer vent the other day on a commercial project. The architect specified a particular make/model number of the dryer and showed the long run in the plans. Bingo, it now passes code where it would normally not.
Comments? (I wouldn't put it in a Summary section.)
"The electrical system does not include arc-fault circuit interrupters (AFCIs) for 15 and 20 amp branch circuits protecting rooms such as family rooms, living rooms, dining rooms, offices, libraries, dens, sun rooms, recreation rooms, closets, hallways, or similar rooms which effective 2008 were mandated by nationally recognized electrical standards. We do not know if your particular county has adopted the 2008 standards and we do not know if the permit was initiated on this home before the effective date of the rule implementation. Therefore, we suggest that you consult with your local building code enforcement office about this matter. Note that we consider AFCIs an important safety feature and consideration should be given to upgrading the circuits regardless of the regulatory requirements in effect at the time of construction." “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
Didn't you use "code" in making an initial judgment that the length was too "long"?
Will you go to the trouble of keeping up with the adoption dates of each locale so that you can put it in the summary when necessary? B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
| Canadian Equipment Inspectors Needed! | Quiktrak Inc | Canadian Inspectors | 15 | 2/7/08 6:15 PM |
| Tidbits from the ASHI Message Board | jbushart | Miscellaneous Discussion for Inspectors | 124 | 4/27/07 12:05 PM |
