Old 2/20/07, 9:48 PM
sspradling sspradling is offline
Please Note: sspradling is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default No bushings in the panel
All the branch wiring left the panel (Sylvania) through the bottom knock out, with no bushing. Would you call this out as a defect?
Stu
Old 2/20/07, 9:49 PM
bkelly1's Avatar
bkelly1 bkelly1 is offline
Please Note: bkelly1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: No bushings in the panel
Yes.
Old 2/20/07, 10:11 PM
Thanks, Ben. I should know this, but I'm stumbling around for wording. Any suggestions?
Stu
Old 2/20/07, 10:52 PM
Unmoderated Guest
I don't understand this description at all.
Old 2/20/07, 11:40 PM
thejnicki's Avatar
thejnicki thejnicki is offline
Maybe something like, " Wiring at main panel lacked proper bushings and/or wire clamps, this applicaiton is incorrect and we suggest repair"
Timothy Hejnicki
All-Specs Property Inspections
(707) 428-3544
Old 2/21/07, 1:00 AM
whandley's Avatar
whandley whandley is offline
Please Note: whandley is a non-member guest and is in no way affiliated with InterNACHI or its members.
Missing service panel protective knock out grommets, (Unsafe Condition - wiring, cable, conductors, whatever are subject to physical damage as a result of same).
Old 2/21/07, 7:56 AM
Thanks Tim. Thanks Will. Sorry Speedman.
Stu
Old 2/21/07, 8:44 AM
jwortham1 jwortham1 is offline
"There is wiring entering the panel without the proper protective bushings. Wiring that enters the panel should be solidly anchored and protected where it enters the panel by a bushing to prevent the sharp edges of the panel box from damaging the wiring and creating an equipment/safety hazard. Recommend installation of the proper connectors by a licensed electrical contractor. "
Jeffrey Wortham
ANS Inspections, Inc.
www.ansinspections.com
630.276.8440
638 Langford Drive
Bolingbrook, IL 60440
NACHI ID:04050181
Old 2/21/07, 9:04 AM
Nice, Jeffrey. Thanks to all that understood what I was talking about. If I could just figure out the darn photo upload....I resized the photos of this to 640x480, and it was still 111kb. Oh well, some changes aren't really better, but that's another thread somewhere else. Have a great week, guys!
Stu
Old 2/21/07, 10:17 AM
tneumann's Avatar
tneumann tneumann is offline
Resize them to 500 x whatever it works everytime....
Old 2/21/07, 11:58 AM
wforsyth's Avatar
wforsyth wforsyth is offline
Please Note: wforsyth is a non-member guest and is in no way affiliated with InterNACHI or its members.
When you say the bottom knock out, are you referring to the one in the base of the panel, or the bottom knockout in the front of the panel? I got a really goofy image and can't picture it as well.
Thanks.
Old 2/21/07, 3:54 PM
Peter Doane's Avatar
Thanks.
The front would be an open breaker slot. He's talking about panel knock outs with out wire protection clamps/ bushings to hold the wire comming through the panel and also protects them from damage.
Peter Doane
NACHI ID# 05120681
Old 2/21/07, 3:57 PM
Like this picture
Peter Doane
NACHI ID# 05120681
Old 2/21/07, 4:00 PM
tneumann's Avatar
Pictures would be helpful.....but when he says
Pretty good sign he DOESN'T mean the front knockout, bottom, middle or otherwise.
Old 2/21/07, 6:13 PM
He probably dosnt know that "Sylvania" could also be a Zinsco too
Peter Doane
NACHI ID# 05120681
National Electrical Code Information and Discussion jtedesco1 Electrical Inspections 50 6/15/10 7:28 PM
Panel Inspection Safety roconnor Electrical Inspections 10 9/24/06 9:02 PM
